rear sway bar?
The tip I got from the vendors is to be sure the rear bar is not thicker than the front. My front measures 1 1/8" diam.
I also plan to go with 15" or 16" alloy wheels the next time I need tires. The shorter sidewalls help handling also.
will lift the sagging EXT tail
also takes out most sway at 10 psi +
then, if you need more handling improvement
the ADDCO sway bar
http://www.addco.net/Ford-GMC_AntiSwaybars.htm#Fordm
let's see if this link works:
http://store.summitracing.com/partde...5&autoview=sku
However, even the cargo springs for the Aerostar seem kind of soft, so I would also add the air bags in the springs and pump them up when carrying heavy loads or towing a trailer. And then find some shocks that have higher damping rates than stock.
Beaned
The only warning about increasing rear roll stiffness has to do with increasing rollover tendancy at the limit of handling response. Any aftermarket sway bar should be OK as should all air springs. WAY TOO MUCH stiffness will make it CONSIDERABLY easier to rollover or lose control, on any vehicle generally.
Adding new tires will help the Aerostar If the tires are better quality than the previous ones. Another set of cheap ones may show little or no improvement.
If you still have the stock Ford tie rod ends you might try replacing those too. Try adding tire pressure up to limit on tire sidewall and observe if it helps your sway.
We look forward to your report on the sway bar & new tires.
Last edited by TheHandyman; Sep 11, 2007 at 08:10 PM. Reason: cuz it needs it! grammer..
There are limits to stiffness, and too stiff can cause problems, but most rollovers are associated with soft suspensions and tires, not stiff. One example is the seemingly tall Dodge Sprinter. That vehicle is somewhat top heavy, but has a lot of roll resistance and rollovers among the Sprinter platform are no more common than rollovers in other full sizes vans.
Note that these were NOT just adding an aftermarket anti-sway bar. But adding springs for carrying extra weight which also raised the rear of the vehicle markedly and changed the handling charactaristics at the limit. The changes were hardly noticable most of the time, but in accident avoidance type manouvers the vehicles were much more unstable and dangerous. I'm much more aware of this condition now in any modified vehicle.
Beware overly strong rear springs and/or raising the rear ride height much over stock. I'm not saying not to modify vehicles, but be aware how your vehicle handles after doing so. each modification does change the vehicle from stock. On a stock understeering type van like an Aero some change is a good thing. My Aero has only once felt dangerous with all the extra springs I've had to add to carry the weight, and I think it may've been due to high speeds through a corner with a low tire & not taking the overload springs out when they were not needed.
Adding just a sway bar will probably be ok in most cases. I've read to uprate the front bar at the same time as the rear to maintain the same front to rear balance, but I think this isn't necessary on the Aerostar, on a lighter sports-type car maybe so.
B Dobz, let us know how it works out. The sway bar was a change I wanted to make, but sold the bar before I ever had time & place to install it. My air shocks & stuff help enough.
As I posted earlier, I installed the Hellwig rear sway bar and the difference in handeling was a marked improvement. My van has 95'000 on it and the springs are in pretty good shape. It corners better and without as much roll. It feels much more stable. I highly recommend it. Hope this helps.
Beaned
'97 3.0 Shorty
Frankly, I thought rear wheel drive cars with solid axle casing (not independent suspension) were supposed to not need anti-sway bars in the rear.
One thing to check on the Aerostar is whether the stock front bar's bushings are all shot. You can replace them and I suggest buying a new set of aftermarket links.
There is another handling trade off. The greater the roll resistance, the less the cornering forces will compress the outside suspension or raise the inside suspension. But it also results in greater weight transfer from the inside to the outside suspension. This results in loss of traction on the inside tires while increase of traction on the outside tires. But the loss is always greater than the gain for most cars, so it's a net loss of traction. These effects are magnified by high center of mass, like with a tall van.
The stock Aerostar suspension probably has more front roll stiffness than rear, resulting in understeer. This is how Ford tends to set most of their cars up, as people's reaction to understeer is to naturally lift up on the gas and apply the brakes. You can neutralize the effect by adding a roll bar in the back to increase the roll stiffness. But too much will cause oversteer, where the proper response is not so obvious.
I'll have to admit though, that shortly after I installed my rear sway bar, I actually got the rear of my 4wd van to swing out on a particularly hard turn. Maybe the bar was set up too stiffly.
