96 Brakes pull to left
Old Sep 10, 2007 | 09:00 AM
kcenicola's Avatar
kcenicola
Unhappy 96 Brakes pull to left
I've got a 96 2WD F150 5.0L. My brake lines were rusted out so I replaced all the brakelines to all 4 wheels, I replaced the front calipers, hoses, rotors and pads as well as the rear cylinders, drums, shoes and hardware.
The truck pulls to the left when braking. I thought it might be a bad driver side front caliper so I replaced it. This made no difference. I've tried semi-metallic and full ceramic pads and thi made no difference either.
Very frustrated. Have bled the brakes at all 4 wheels. Still pulling to left. Everything is brand new. What could be making the brakes pull to the left?
Ken
Old Sep 10, 2007 | 09:31 AM
quicklook2's Avatar
quicklook2
the rubber lines were also replaced?
could be clogged.
Old Sep 10, 2007 | 09:38 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
A bad Passenger side caliper(not working right) will make it pull left.......have you looked at that one?
I'd have the rotors checked for imbalance too......it's possible the drivers side is a little thicker.....causing that brake to grab sooner....and pull.
Other than that.......I'm stymied.
Good Luck
Bob
Old Sep 10, 2007 | 09:41 AM
Skandocious's Avatar
Skandocious
Good call. Seems counterintuitive but that makes sense.
Old Sep 10, 2007 | 12:29 PM
Phillip Guidry's Avatar
Phillip Guidry
Does it jerk the steerwheel to the left...or...does the whole truck drift to the left ?
Old Sep 10, 2007 | 01:22 PM
andym's Avatar
andym
This is good advice. Even though you replaced them, depending on the quality of parts that you used, this is the most common culprit of a pull.
Also, worn suspension parts can cause a pull. I've seen bad radius arm bushings do this.
On this.... I'll just be nice and say that you're 1 for 2 with your post.
Old Sep 10, 2007 | 06:01 PM
kcenicola's Avatar
kcenicola
I replaced all the rubber hoses and I even swapped out the new left rotor for a different new rotor and that did not help.
I also had the front end aligned. I don't know what's going on. I've never had a problem after replacing everything with new parts. The only thing I haven't replaced is the rear ABS prop valve. The rear ABS does not work anymore but I don't see how that could affect the pulling to the left. I'll replace that next.
Old Sep 10, 2007 | 06:15 PM
kcb37's Avatar
kcb37
When you got your alignment done did they say if any of your steering or suspension was bad? Or did they even check? If your brakes are all working properly then it has to be worn out steering or suspension.
Old Sep 10, 2007 | 06:45 PM
quicklook2's Avatar
quicklook2
right caliper is my new vote.
Old Sep 10, 2007 | 08:01 PM
netscaner's Avatar
netscaner
Rear brakes can cause a pull to one side also, as well as a funny tire.
Try swapping tires from side to side is the easiest to try. First front then rear.
Old Sep 10, 2007 | 09:09 PM
kcenicola's Avatar
kcenicola
You guys are all helping with great suggestions. I will fix this by winter time. I will try the tire swap. The steering and tie rods all seem firm to me but I won't rule out anything.
One thing that has always concerned me is that an auto technician years ago told me that the caliper design on these Ford trucks is one that seizes and fails a lot. To that end it's almost impossible to purchase a "New" caliper, they are all remans. I spent the extra dollars and got the Raybestos calipers this time because I have had seizing caliper problems on past front break jobs.
Will keep all updated as I continue to troubleshoot.
Old Sep 11, 2007 | 06:05 AM
alz's Avatar
alz
Did it pull at all before the brake job?
Old Sep 11, 2007 | 06:16 AM
jroehl's Avatar
jroehl
Did you have your rotors turned--even the new ones? If one side is warped and the other not, it will not have as much braking power as the true rotor and the truck will pull to the side with the greater braking power. New rotors can be warped out of the box...
Jason
Old Sep 11, 2007 | 08:32 AM
TheRoadVirus's Avatar
TheRoadVirus
I still haven't heard a mention of you addressing the passenger side caliper yet. Have you looked into that?
Old Sep 11, 2007 | 08:37 AM
quicklook2's Avatar
quicklook2
i was thinking the same thing.
