Oil Filter Change
Old Sep 9, 2007 | 08:26 PM
moonlighter's Avatar
moonlighter
Oil Filter Change
Well I read on here how bad a job it was to change oil filter the first time, I was too stupid to listen. Wished I had carried to dealer. By the way it's 07 150 w/ 5.4 , finally went and purchased a strap type filter wrench at Advance Auto, that did the trick. Whoever at Ford, that designed where to put oil filter needs to be designing women's shoes! I'll stop venting now.
Old Sep 9, 2007 | 08:52 PM
osteodoc08's Avatar
osteodoc08
Get an end style filter wrench and all of your problems are pretty much solved. Still messy, but makes taking the filter off really easy.
Old Sep 10, 2007 | 01:37 AM
ford-lover's Avatar
ford-lover
Greetings to everyone. I am a new member of this forum.
I just did the 1st oil change in my 07 5.4L last week and boy oh boy did I ever had fun.
I purchased a Cap style filter wrench ( PLEWS LubriMatic 93mm with 15and 36 flutes) to do the job. The cap is the right size but very shallow and the flutes do not fit properly on the filter. The wrench "pops" out every time I turn it. I ended up puchased a strap wrench and it did the tricks.
If anyone knows where to buy or the brand and part numbers of a better fit filter wrench for the OEM FL820S filter please let me know.
Thanks.
______
2007 F150 5.4L 2WD 3.73LS SCAB
Old Sep 10, 2007 | 08:09 AM
FTE Ken's Avatar
FTE Ken
I use the K&N filters which have a hex nut on the end. You can remove and install the filter quite easily with a socket or box-end wrench.
Old Sep 10, 2007 | 08:33 AM
jmizell49's Avatar
jmizell49
I didn't listen either. After drawing a little blood, I was able to loosen the filter with a large pair of pliers form underneath.
Old Sep 10, 2007 | 04:03 PM
moonlighter
Walmart sells a wrench to fit on the end of the FL820s filter, I don't remember part #, but it fits perfect.
Old Sep 10, 2007 | 04:40 PM
Firemut30's Avatar
Firemut30
Only my first time is it too hard to take off, damn robots are strong as hell!! After that I've been able to take them off with my hands, and no oil leakage between changes(its a gift,HaHa). Did I mention I was double jointed?? JUST JOKING!
Old Sep 10, 2007 | 05:14 PM
DaMole's Avatar
DaMole
I hand tighten mine also and have never had a problem. It is a ton easier than before.
Old Sep 10, 2007 | 05:33 PM
DoughboyRacing's Avatar
DoughboyRacing
X2
Old Sep 10, 2007 | 06:01 PM
ford-lover's Avatar
ford-lover
Thanks for all th info.
I prefer to use the wrench because I am a small guy with small hands and muscles.
I will try Walmart to see if they have it. I am in British columbia, Canada. Walmart may carry different stocks than the states.
