Belt Size Question...
Old Sep 9, 2007 | 04:25 PM
BushyTea's Avatar
BushyTea
I have a 351 Windsor that was put into my 66 ford F100. Not sure what year the motor came out of or anything like that though.
All I have on the motor pulley wise is the alt., water pump and crank pulley. My pullies have 3 slots on them as well which you can see in the pic below.
The belt used to go around all 3 but the alt. doesn't line up with the water pump pulley so it would make the alt squeal and probably tore up the last one. So there is one belt going from the groove closest to the motor on the crank pulley to the alt.
My question is does anybody know what size belt to get to run from the water pump pulley to the crank pulley?
Thanks!
