need printer install/computer help
Old Sep 8, 2007 | 03:44 PM
cjben's Avatar
cjben
I am trying to reinstall my printer on my computer. windows xp operating system. when I put the installation cd in to install it,I get a pop-up box. It says 16 bit windows subsytem C:\winnt\system32\autoexec.nt. the system file is not suitable for running ms-dos and microsoft windows applications. choose "close to terminate the application. what do i need to do to correct this? I am not that computer savvy,so put it in simple terms please this printer has worked on this computer before,I am not sure why I can't install it right now. thanks for the help!!
Old Sep 8, 2007 | 03:50 PM
tewferford's Avatar
tewferford
You will probably have to go online and download an updated driver. That driver may not be compatable with XP anymore.
Old Sep 8, 2007 | 05:07 PM
cjben's Avatar
cjben
ok,I downloaded a driver that is xp compatable. Now when I go to add printer,I get a pop up that says printer spooler service not running. what is that and how do I start it up? thanks
Old Sep 8, 2007 | 06:22 PM
tewferford's Avatar
tewferford
Go to the control panel and click on the printer icon. Make sure that printer is enabled.
Old Sep 8, 2007 | 06:43 PM
Mil1ion's Avatar
Mil1ion
what printer is it ?
Old Sep 8, 2007 | 07:11 PM
cjben's Avatar
cjben
lexmark z12. there is no printer icon on the task bar. where else would i find it? the lexmark z12 was installed,but i uninstalled it because the computer was having problems communicating with the printer. I put the install cd in to reinstall the printer,and that is when i had the problem i started that caused me to start this thread.
Old Sep 8, 2007 | 07:34 PM
jimbo beam's Avatar
jimbo beam
With the cd in the machine click on the my computer icon, either on your desktop screen or in the start menu. Once in the my computer folder right click on the icon for your cd rom drive, select "explore" from the list.
That should bring up a window with all the files on your printers cd, look around for files or folders named installer.
It sounds like your have the same problem I had with a old epson printer, after I reinstalled XP on my machine. There is probably a XP installer on the cd but its trying to load the wrong one.
Old Sep 8, 2007 | 08:11 PM
modar's Avatar
modar
try a system restore, it will undo the problem. like it neva happend
Old Sep 8, 2007 | 08:18 PM
donjamer's Avatar
donjamer
Goto Control Panel
Select Administrative tools
Select Services
Select the Print Spooler service then you can stop or start the service
Old Sep 8, 2007 | 09:38 PM
cjben's Avatar
cjben
thanks for all the help guys. what don jamer suggested worked,then I just installed the printer manually. works like a champ now!!
Old Sep 8, 2007 | 09:48 PM
tewferford's Avatar
tewferford
That had to be a lucky guess Although I was going there next.
Old Sep 9, 2007 | 12:40 AM
cjben's Avatar
cjben
I wouldn't consider anything posted by don jamer related to computers a lucky guess considering he works on puters for a living
Old Sep 9, 2007 | 01:13 AM
tewferford's Avatar
tewferford
Okay, now I see. You led us all into a false sense of security, knowing all along some puter geek would stop by soon, and help your sorry nimble witted brain with your cheap sorry azz printer. Now, heres the kicker. We all fed you false information to make sure your little printer would not work.For as long as you believed in us. SO! the joke is on you.
Old Sep 9, 2007 | 11:13 AM
BIGKEN's Avatar
BIGKEN
donjamer...Big Don...you're our hero!!!
Old Sep 9, 2007 | 11:49 AM
cjben's Avatar
cjben
hope you guys keep your day jobs and don't hit the road on a comedy tour any time soon!!
