Need a general price cost
1st of all welcome to the FTE Website & this 1961 to 1966 F Series Forum Robbie.
There are way too many variables to really guestimate the answer to your question. Besides that this forum is about 61-66 F Series trucks, AKA the Slick 60's style pick up.
Never the less, there are some basics that apply like: Who'll do the work? Do you want new or used parts? What size/type power train are you considering using? and so forth.
I have retrofitted many an upgrade in FoMoCo pickups between model years 1961 thru 1973. Costs & requirements are pretty much the same. It ranges from a few hundred to a few thousand dollars, again depending on what the owner wants to use for the upgrades. Perhaps if you could be more specific we could be more helpful.
FBp
Disc brake swap is easy. Click here to read a how-to with photos.
"Modern" engine? Nothing wrong with the engines offered 1965 and later. The 352 is an 'FE', same as 390 and the 360 used in later trucks, just different guts. The sixes are also very good engines and worn ones can be replaced by the excellent 300 six. With electronic igntion such as Petronix or Duraspark and maybe a 'new' carb/intake system there's not need to swap out the engine.
If you truly want a 'modern' truck, then you really should just buy something newer with fuel injection, etc as it's not cost effective to upgrade an older truck unless you truly want it as a long term hobby.
