Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
1st Gen. Lightning.
Old Sep 8, 2007 | 06:04 AM
W6e6s6W's Avatar
W6e6s6W
1st Gen. Lightning.
I like the first generation of lightnings (and love the second),
But I'll be looking for a new ride when my 88 ranger dies.
I was wondering if you put a supercharger on a 95 lightning,
would you have to upgrade any components like piston rods,
driveshaft, etc. ?
Old Sep 8, 2007 | 12:08 PM
wd13's Avatar
wd13
If you keep the boost at moderate levels (6-8lbs) you wouldn't need any internal modifications. I would however, recommend larger injectors and a good tune with the addition of a supercharger.
Old Sep 14, 2007 | 04:01 PM
Blurry94's Avatar
Blurry94
Those shortblocks can handle quite a bit; 10-12psi wont be a problem for a daily driver as long as the tune is dialed in properly.
I'd also recommend installed an aftermarket valve body to firm up the shifts and reduce friction and a set of traction bars to keep the dreaded wheel hop from snapping an axle and or driveshaft.
Old Nov 12, 2007 | 12:11 AM
Gen 1 driver's Avatar
Gen 1 driver
Good advice in these posts. I can't stress enough how important it is to get a chip and tune. The stock blocks can easily handle 12 pounds of boost but with a bad or no tune all kinds of bad things can happen. The dyno tune and chip will also tighten up your shifts. The tune I had done allows me to run a race tune and with the flick of a switch go back to a much safer daily driver tune. A little pricey $500.00 including Chip and the dyno passes required to complete the tune, but much cheaper than a new short block.
My 2 cents
Mike
383lightning
Aug 3, 2014 02:20 PM
El Camino Man
Modular V8 (4.6L, 5.4L)
May 13, 2014 09:13 AM
bhelmuth
Sep 8, 2010 11:29 AM
jermdawg
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 11, 2006 03:31 PM
Jason Lewis
Mar 28, 2006 09:11 AM
