How Do I Identify?
Old Sep 7, 2007 | 01:45 PM
drking's Avatar
drking
How Do I Identify?
My front differential type?
My rear differential type?
it has the number 30280 on the rear of it, just above the fill/level plug
My transfer case type?
it is shaped like a lozenge-pill, says "ATF" on it.
I need to know what type of fluids to use in each, and whether or not to use additives for any of them.
I used Valvoline Dextron 3 for the transmission.
1984 F350 460V8 4BL, 4wd, C6 transmission
Old Sep 7, 2007 | 03:02 PM
rclarke's Avatar
rclarke
The rear end should be happy with any high quality 85/140 gear oil with friction modifier (8 ozs or 2 bottles on a 10" or bigger) added if its a traction lock. The transfer case uses the same oil as the C6(atf).
Old Sep 7, 2007 | 09:58 PM
projectnitemare's Avatar
projectnitemare
The front axle will use the same as the rear. I don't recall and front limited slips in that era. The front will be either a HD Dana 44 or a Dana 60m gear oil is fine. The t-case should be a BW1356 I believe, most all the aluminum case t-cases take ATF.
Matt
Old Sep 10, 2007 | 01:25 AM
drking's Avatar
drking
Still need to ID my axles
Hey all,
I have new information:
I found tags on my front and rear axles. The front one has this on the front:
3,54 E3TA AFD
610200-1
the rear has this:
3,54 F4TA ANC
665197-5 IS
Any ideas what these numbers mean or where to go to figure this out?
Old Sep 10, 2007 | 09:25 AM
projectnitemare
Someone can probably identify the axles from those number but there should be some more info, such as ring gear size. You probably have the sterling rear and should be a 10.25in ring gear. The front if it's a Dana 44 should be 8. ( I forget the other number) and a Dana 60 is around 9.75 if I recall correctly. From your info I can tell you both are open diffs so you don't need any friction modifier, if they were there would be a "L" in the gear ratio,(ex open 3.54, LS 3L54).
Matt
Nothing Special
Offroad & 4x4
72
Jan 18, 2020 01:43 PM
kshack90
2004 - 2008 F150
Jan 29, 2016 11:50 AM
SNIPER168308
Aug 23, 2015 01:02 PM
Eddie C
Sep 30, 2014 09:47 PM
capriceragtop
Aug 27, 2014 01:01 PM
