Engine Block Heater?'s
Old Sep 9, 2007 | 08:27 PM
vlietracer64's Avatar
vlietracer64
It sounded like it made sense to me when my buddy from Mack trucks told it to me, but after posting it and looking at it i thought it was wrong. I was pretty sure that it was the other way but figured i would wait and let someone confirm it. Sorry for the misguided info. So as it seems leaving the heater plugged in and engine running will actually raise the resistance and lower the amperage thus causing no damage to the heater.
Old Sep 9, 2007 | 09:44 PM
Rizvi54's Avatar
Rizvi54
Originally Posted by A. Michael Foxtrot
All you'd need to do is purchase a cord and wire it up.
How exactly do you wire it up?
Old Sep 9, 2007 | 09:52 PM
04Xcursion's Avatar
04Xcursion
You plug in one end of the cord (special connector) to the block heater and route the rest of the cord safely through the engine bay to a point where you can plug it into and extension cord.
Old Sep 9, 2007 | 10:19 PM
mrxlh's Avatar
mrxlh
Pics are in the tech folder up top.
Old Sep 10, 2007 | 11:36 AM
bradcollison's Avatar
bradcollison
My block heater runs for about an 1 hour or so before I take off. I keep my truck in an attached garage so it stays pretty warm in there.
I fiqure it is easier on the engine to start a little warmer and it is nice to have heat right away. It costs less for electricity ($.10) vs. the much higher cost of the additional fuel it takes to warm the engine up from a lower temperature if I didn't plug it in.
Old Sep 10, 2007 | 12:23 PM
Beamer 2's Avatar
Beamer 2
I have a 2007 6.0 F250 I bought in January 2007. It has no block heater and last winter it got -15 and with the truck sitting out side I had no problems starting. A friend told me about Power Service anti-gel. I did stall out (temporary freeze up) so I use Power Service year round. Only other thing is my truck had Ford 15W-40 when I got it and my dealer put 15W-40 at its 1st oil change. It was -5 the day my dealer changed the oil. Since then I've changed the oil to Shell Rotella T 10W-30.
Old Sep 11, 2007 | 12:32 AM
trillian_42's Avatar
trillian_42
But there was no applause...
Originally Posted by rchouser
There is something about the voice of experience.... Those "oh darn" moments do keep life interesting and it is ALWAYS with an audience of some sort. rc
Yes, the extension cord flapping across the driveway really gives it away. And it's always the four-year-old conversationalist across the way that sees it. And remembers it. For years.
/trill
Old Sep 11, 2007 | 08:40 AM
Lonewolftx's Avatar
Lonewolftx
Wink
Here is where it plugs in, above the starter w/ the 2 prong plug.
And it comes out here looking like this.
Old Sep 11, 2007 | 10:12 AM
kw5413's Avatar
kw5413
Even though I live in the DFW area I often used my block heater. Usually below 38 degrees. Mainly due to short (3 mile) drive to the office.
I used the Marinco plug for easy access. Check my gallery for more info.
https://www.ford-trucks.com/user_gal...&albumid=18820
Old Sep 11, 2007 | 11:37 AM
CLVNGR's Avatar
CLVNGR
I live in Alaska, and the rule up here is "Plug at 20". Meaning if it's 20 degrees or below you should plug in your vehicle. Of course, I believe they're talking about all vehicles. Up here not only diesels have them, but pretty much all vehicles. It makes a huge difference, because my first winter up here, I didn't have a block heater in either of my vehicles, but...now my wife and I have diesels, so of course they have them. But anyway...I just left them plugged in all night without a timer...didn't seem to hurt anything.
Old Sep 12, 2007 | 07:46 PM
Mustangbru8's Avatar
Mustangbru8
your electric bill probably took a nice hit though
Old Sep 12, 2007 | 07:47 PM
JB666Rock's Avatar
JB666Rock
I found mine this afternoon!! It was tucked behind the grille on the passenger's side, with the cap over the plug, zip tied to the bumper bracket..
Thanks for the help guys!!!
Old Sep 13, 2007 | 08:45 AM
  #28
jomac11's Avatar
jomac11
I have never really paid any attention to whether my truck has one or not, but I don't remember seeing it listed on the window sticker. Anyone know a part # and where to get that cord if I need to get one?
Old Sep 13, 2007 | 10:27 AM
  #29
CLVNGR's Avatar
CLVNGR
Well...if it did, I wouldn't notice. I live on base here at Elmendorf, and my "rent" has all utilities included. I can keep all the lights on and keep the temp at 90 all day if I wanted. Wouldn't make any difference to me really. Now...if I did actually have to worry about it, then yeah, I'd probably get timers.
Old Sep 13, 2007 | 10:33 AM
  #30
JB666Rock's Avatar
JB666Rock
Take a few minutes and look at your truck thoroughly first before you contact the dealer about a plug/cord you may not need. I was flat out TOLD I didn't have one in my truck (by the dealer) and that I could have one installed. Had I not looked, and dropped the truck off, I could have been ripped off big time..
