Offroad & 4x4
rear traction bar mount location
Old Sep 7, 2007 | 12:35 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
heres some tech for yall.....
i'll be building my rear traction bars sooner than later and im wondering what is the best position on the rear axle to mount my tabs...
1. On the top
2. On the bottom
3. straight in line with bar?
ive heard the bottom is the best, but you loose ground clearance....im not to worried about the ground clearance b/c of the bigass tires ill be running....
Old Sep 7, 2007 | 12:36 PM
quadzjr's Avatar
quadzjr
oh and i dont know if this matters but the top part of the traction bar will be mounted to my subframe (14" lower than frame)
heims on the frame end and bushing on the axle...
Old Sep 7, 2007 | 07:13 PM
quadzjr's Avatar
quadzjr
wtf?......
Old Sep 8, 2007 | 03:10 AM
fishmanndotcom's Avatar
fishmanndotcom
check out mine in my picasa gallery in my sig. i have one on both my powerstroke and my bronco, holding up great with all the flex in the world. heck i have the ladder bar mounted when i took the pic of my bronco ticked out on my trailer in my sig.
kubota has some as well i believe
-cutts-
Old Sep 10, 2007 | 04:43 PM
wvmudder's Avatar
wvmudder
I dont have any pics of them, but around here the tractor tire trucks usually use what looks like a three link. One from the top and one from the bottom on each side. For serious muddin, flex isnt much of a concern, unless its also a street legal truck. BTW, wtf are the lift laws in Florida?
Old Sep 10, 2007 | 07:49 PM
quadzjr's Avatar
quadzjr
i dont remember all the laws off hand....but this is for for the rear....and leaf springs....why do i need a 3 link?
Old Sep 11, 2007 | 07:07 PM
wvmudder's Avatar
wvmudder
Sorry for the confusion, it only looks like a 3 link. It has one link from the top of the axle to a crossmember, then one link on each side from the bottom of the axle to the frame. The setup is used with leaf springs. They work great but do limit flex.
Old Sep 11, 2007 | 07:32 PM
quadzjr's Avatar
quadzjr
oh ok....so just the reg. two traction bars....then 1 to the top of the chunk.....right?
wouldn't the top link get in the way of the driveshaft?
where on the axle would the two other links go....on the bottom, top, or center of axle???????
Old Sep 11, 2007 | 08:14 PM
chrono4's Avatar
chrono4
a single traction bar with a shackle on the frame end is all that is needed.
Old Sep 11, 2007 | 08:28 PM
chrono4's Avatar
chrono4
excuse the distorted leafs, quicky in paint.
Old Sep 11, 2007 | 08:45 PM
quadzjr's Avatar
quadzjr
im just going to use 1 bar on each side....not like you drawn...
with no shackle....going from my drop subframe to the rearend...
i just want to know where on the rear axle should the bars be mounted?
Old Sep 16, 2007 | 01:29 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Quad,
Im going to be building a set of traction bars like you mentioned for my D60. Just 1 bar on each side not a triangulated ladder bar like Chrono "aka paint-master" suggested (jusk kidding chrono...that was a good job!) My question is would you mount the bar inboard or outboard of the spring? I have about 2" of useable space between the brake drum and leaf spring and 1 1/2" of useable space between the leaf spring and shock mount. Its going to be tight to put a heim or bushing end between either of those places. Anything wrong with mounting the bars about half way between the center section and shock mount? Then my plan was to build a crossmember to atatch the bars to up front and maybe incorporate a drive shaft loop. What do you think?
Old Sep 16, 2007 | 03:27 PM
quadzjr's Avatar
quadzjr
i will be putting mine on the inside of the spring....
what i did on my dads ford to fix the problem you were having was just use the torch burn the shock brackets off and reweld them on the top or close to it and weld it back on and run a shorter shock then just have the traction bar mount where the shock mount was....worked great...
this is a crazy thought but has anyone thought of putting a shock or hydro cylinder or somting inline with the traction bar so that it would eliminate the axle wrap but yet still alow flex?
Old Sep 16, 2007 | 05:26 PM
STGFordCrazy04
Im going to weld some brackets to the axle between the center section and that round thing on the tube. I thought about using the shock mount as a mounting point but then Id have to buy new shocks.
I think trailmaster did that a few years back. It was one of those deals that bolt to the top of the spring plate and run backwards toward the rear of the truck. CRAP IMHO!
I started working on my bars this afternoon. Ill let you know how it goes.
Old Sep 16, 2007 | 06:01 PM
quadzjr's Avatar
quadzjr
sweet......
good luck...right now the traction bars are not a high priority in my truck...
