79 block
Old Sep 7, 2007 | 08:09 AM
lemcham's Avatar
lemcham
79 block
Would 1983 parts form the motor fit right up to a 1979 block. Also would The 79 block bolt right up to my 1983 ford truck? Both engine are 300's.
Old Sep 7, 2007 | 10:51 AM
63redtudor's Avatar
63redtudor
Yes, it will work. My '84 has a '79 engine in it. Dropped in just fine, however, some things to keep in mind:
- '83-4 ford changed the block slightly as far as the oil dipstick location. Previously there was only one dipstick location on the block, for the mid-sump pan. I'm not sure, but I think most '80 & later trucks used the rear sump pan whether they were 4x4 or not. For the '79 engine, if it doesn't all ready, you'll need the rear sump pan with the dipstick through the pan. You'll also need the oil pump pick-up tube, support & the main bearing cap bolt.
- Your '83 SHOULD have the duraspark II (DSII) ignition, same as the '79. If not, you might need to convert one way or the other (I'd recomend going to the DSII, a better ignition than the later TFI).
These were the main things that I found. Keep in mind that my '84 is a 4x4 & I was also changing the intake/exhaust, carb & other goodies. Hope this helps.
Edwin
Old Sep 7, 2007 | 04:53 PM
lemcham's Avatar
lemcham
thanx 63redtuder
I will keep that in mind I hope that I am able to do this swap.
