Sponsored by: Real Truck
windshiel wipers
Old Sep 6, 2007 | 12:24 PM
dczrboy's Avatar
dczrboy
windshiel wipers
Hello i am new here but i see you guys are really knowledgable on Fords i have a problem with my 2003 F350 super duty about 6 mos ago when i turn on the wipers it would take about 5 minutes for them to come on but over time it has gotten worse now it takes about an hour i just replaced the motor and it still does the same thing any ideas? thanks in advance
Old Sep 6, 2007 | 06:05 PM
ReAX's Avatar
ReAX
I would suspect either the switch or the GEM.
Old Sep 6, 2007 | 07:11 PM
redford's Avatar
redford
FTE Leadership Emeritus
Try turning the wipers on when the headlight control switch/stalk is in the high beam position. Do the wipers work better or different? If so, it probably means you need a new multifunction switch.
