Gaskets?
Old Aug 28, 2002 | 04:06 PM
teschwab's Avatar
teschwab
Gaskets?
Old Nov 10, 2002 | 05:15 PM
MKPJ1's Avatar
MKPJ1
Gaskets?
Hello,
I'm a novice at rebuilding an engine and I have a few questions that Steve C. doesn't cover. I bought a Victor Reinz gasket set and it has 2 timing cover gaskets? Which one do I use? Second, The head gaskets have one of the large coolant passages blocked. I see where it says Front on the gasket but why is one blocked?
Thanks
Ken
68 F100 390
74 Bronco 351W
Old Nov 10, 2002 | 07:42 PM
Ratsmoker's Avatar
Ratsmoker
Gaskets?
The head gasket may be upside down and I used the rubber timing cover gasket in my felpro kit even though they had a paper one.
Old Nov 11, 2002 | 03:07 AM
Scotty1's Avatar
Scotty1
Gaskets?
Where is the "coolant passage" at?? If it is in the middle of the head then you may be refering to the Heat riser. It is fairly common for after market intake gaskets to have heat risers blocked off. If it is for sure a coolant passage then I don't know what to say.
Scotty
Old Nov 11, 2002 | 05:16 AM
MKPJ1's Avatar
MKPJ1
Gaskets?
Scotty
This is just a "would like to know ?" It's the very front large coolant passage that is blocked by the gasket. I think it is why a lot of people put them on the wrong side. I was just wondering why Ford cut the hole durng casting when they blocked it off anyway?
Thanks
Ken
68 F100 390
74 Bronco 351W
Old Nov 12, 2002 | 11:19 PM
kc8fhs's Avatar
kc8fhs
Gaskets?
If the front holes wasn't blocked in the headgaskets you wouldn't get the proper coolant flow through the heads and it would overheat. This has happened before to others that put the headgasket on with the hole in the front.
Tim
My Truck
http://1969ford.ods.org/mytruck.htm
Old Nov 13, 2002 | 01:43 AM
Scotty1's Avatar
Scotty1
Gaskets?
Now that I understand what you are asking for. Sorry for the misinterp. The other reason ford machined or cast the holes in the head is so the heads could be placed on either side of the motor. Becuase the front passage on the driver side could (is) the rear passage on the Passenger side.
Scotty
Old Nov 15, 2002 | 04:39 PM
MKPJ1's Avatar
MKPJ1
Gaskets?
DUH!
Thanks Scotty. Makes you wonder if I have any business rebuilding a motor? I guess they didn't need to cut the hole in the block though.
Ken
