General Diesel Discussion
auxiliary transmissions
Old Sep 6, 2007 | 07:05 AM
johncp40's Avatar
johncp40
Hi guys
Has anyone added a auxiliary transmission in their trucks, if so what are the pro and cons. Looking into towing RV's from the factory's to the dealers. Has anyone made a decent living doing this?
Thanks
Old Sep 6, 2007 | 12:13 PM
fellro86's Avatar
fellro86
Pros... additional forward gear, gear splitting making it to where you have ratios in between the regular gears
Cons... cost, look for a new unit to run around $3000, and it depends what unit you get as to what all mods you have to make.
Old Sep 7, 2007 | 12:53 PM
rbaker6336's Avatar
rbaker6336
there was a discussion on the 99 to 2003 7.3 forum a few months back might do a search and find it
Old Sep 7, 2007 | 07:08 PM
Kwikkordead's Avatar
Kwikkordead
That was me talking about it and I came to the conclusion that there is nothing out on the market that I really want.
What I want is a VERY close ratio aux tranny that will change engine rpm 200 rpm or less and needs to be minimum 2 speed. 3 or 4 would be more preferable, but there is simply nothing on the market for a pickup truck like that.
HUMPH!!!
So when the money is there I'll probably end up getting a US Gear OD unit and bolt it in.
EDIT: Do a search for "Need to talk gear ratios"
Old Sep 7, 2007 | 07:51 PM
mrxlh's Avatar
mrxlh
Dan, doesn't Ford have a rear diff offered from the factory thats a 2 speed? I know a guy I used to work with put a 2 speed rear in a brand new 05 F350 dually, for towing a 23K emissions testing trailer. (thinking its offered in the 450 550 650) So that would be a direct swap for you.
Old Sep 7, 2007 | 08:04 PM
dragogt's Avatar
dragogt
have you checked out gear venders http://www.gearvendors.com/f2wdt.html
Old Sep 7, 2007 | 08:10 PM
mrxlh's Avatar
mrxlh
I would love one, they don't offer one yet for a 6.0 with the 5r100w yet, or at least its not listed on their site.
By the way, great sig quote.
Old Sep 7, 2007 | 08:18 PM
dragogt's Avatar
dragogt
do you know if anybody has checked w/ their tech dept?
and tks for the complement on the Sig.
Old Sep 7, 2007 | 08:22 PM
mrxlh's Avatar
mrxlh
Yep, I sent them a request for info about 10 minutes ago.
Old Sep 7, 2007 | 08:24 PM
dragogt's Avatar
dragogt
hope it works out for ya
Old Sep 8, 2007 | 07:25 AM
Kwikkordead
I looked at that option on Dana's website and all I could find was a single speed for the 135 axle. Two speeds; I had to get a bigger axle.
I may very well be mistaken on the single speed only.
Since you've seen it in the flesh, so to speak, I'll check around again.
Old Sep 8, 2007 | 07:54 AM
mrxlh's Avatar
mrxlh
Dan, if I remember correctly with the gear that was in it, he was getting like 13mpg towing and 21 empty. Of course mileage results may vary with driver.
It wouldn't be a splitter like a Gear Vendors unit, but the stock gear ratios would be fine for straight towing and, straight empty, due to having to stop to shift.
Old Sep 8, 2007 | 07:56 AM
Kwikkordead
Do you have any way of contacting that individual?
Any leads would be great.
So are those mileage numbers!
Old Sep 8, 2007 | 07:57 AM
mrxlh's Avatar
mrxlh
Yeah he used to be an owner of the company I used to work for. I will try to call him Monday and get the scoop.
Old Sep 8, 2007 | 11:06 AM
yamaguy's Avatar
yamaguy
PM me if you want to talk about the realities of the transport business.
