Sponsored by: Real Truck
Door ajar chime??
Old Sep 5, 2007 | 11:03 PM
erik-the-viking's Avatar
erik-the-viking
Door ajar chime??
Anyone have any ideas why door ajar chime rings even with no key in ignition, no lights on, etc. Only started happening and it's driving me crazy. Any info to correct this problem much appreciated.
2001 7.3L powerstroke Lariat.
Thanks
Erik
Old Sep 6, 2007 | 02:45 AM
ryaneverk2's Avatar
ryaneverk2
Thread moved to Super Duty section.
Old Sep 6, 2007 | 02:59 AM
Beerstalker's Avatar
Beerstalker
Take the cover off the bottom of the steering column and check the black wire with pink tracer to make sure it hasn't been worn and started shorting to ground.
Old Sep 6, 2007 | 10:46 AM
94yj's Avatar
94yj
did this start after a heavy rain?
Old Sep 6, 2007 | 12:08 PM
erik-the-viking
No... Not much rain in AZ lately... What preceded this was that I ignored the seatbelt chime on a trip home from work to see how long it would ring... Next day, door ajar chime began ringing as soon as I opened the door and before I inserted the key into ignition. Hasn't stopped since...
P.S.
Seatbelt chime didn't stop until I put on seatbelt...
Old Sep 6, 2007 | 12:51 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Erik Your owners manual gives the procedure on how to turn off the seat belt dinger. Or search this forum there are several threads with the procedure.
Old Sep 6, 2007 | 03:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Next time it does it, just wiggle the ignition switch...do NOT install the key, see if it stops.
Old Sep 6, 2007 | 04:11 PM
erik-the-viking
Fixed it! The black cable that connects to the ignition barrel was loose so I removed barrel, tightened the cable and voila!
Thanks All...
Adventure Rider
6.7L Power Stroke Diesel
Sep 8, 2012 01:57 PM
scooter_nate
Sep 21, 2010 08:20 PM
Huckle berry
Nov 26, 2007 06:13 PM
baredog26
Feb 26, 2005 07:41 AM
rebel_yell23
1983 - 2012 Ranger & B-Series
15
May 23, 2002 08:19 AM
