Where to get special tool
Old Sep 5, 2007 | 01:56 PM
lionsteve's Avatar
lionsteve
Need to find an axle hub seal installer for a 2000 4X4. Any ideas on part number or where to get one?
Steve
Old Sep 5, 2007 | 04:03 PM
wlihntr's Avatar
wlihntr
i have not yet had my hubs apart but have read intructions on to R&R them. i dont see where any special tool is needed, http://guzzle.rbmicro.com/nblube.html or am i missing something?
Old Sep 5, 2007 | 04:35 PM
magnum300's Avatar
magnum300
for front or rear?
Old Sep 5, 2007 | 04:42 PM
anotherfordguy's Avatar
anotherfordguy
If you are talking about the seal behind the wheel hub that gets pressed on the outer axle shaft. You can make your own with a 1 1/4 (may be 1 3/8) pipe and the corasponding threaded pipe flange and cap from any hardware store. The pipe should just fit over the outer axle shaft. Cut down the OD of the flange to fit the OD of the seal but small enough to fit inside the knuckle. This allows you to get the seal pressed on the axle with out damaging it and also helps install the axle and seal back in the knuckle.
Old Sep 5, 2007 | 08:04 PM
Vader0121's Avatar
Vader0121
Site saved me $ again
Old Sep 5, 2007 | 08:06 PM
Vader0121's Avatar
Vader0121
Just looked at mine 1-1/4" pipe, cap, and floor flange- had to grind flange down slighlty used a bench grinder. Tool worked good.
Old Sep 5, 2007 | 08:44 PM
Fat Diesel's Avatar
Fat Diesel
Yep. Just like mine.
