Oil reservior problem
Old Sep 5, 2007 | 01:53 PM
lionsteve's Avatar
lionsteve
Intermittenly oil reservior goes empty and truck won't run. Oil pump has been changed and there is no oil dripping out of the reservior. Any ideas what this might be or where to look?
Thanks in advance.
Steve
Old Sep 5, 2007 | 04:19 PM
Mach1's Avatar
Mach1
There is a check valve in the V for anti-drain back..sometimes there, Usually though the LPOP pump is the problem 80% of the time..From what I have seen any problems feeding the HPOP is coming from the LPOP not being able to feed it enough oil..
Old Sep 5, 2007 | 05:17 PM
Action4478's Avatar
Action4478
Thanks in advance.
Steve
Have you checked the crankcase level?
Old Sep 5, 2007 | 05:21 PM
Action4478's Avatar
Action4478
Could also be the drainback valve or some junk in the IPR ,or lastly a stuck open injector,...the latter would most likely give you excessive smoke....
Old Sep 5, 2007 | 05:24 PM
Action4478's Avatar
Action4478
Could also be the drainback check valve ,some junk in the IPR.....
