Battery ground cable
Old Sep 5, 2007 | 09:46 AM
southpole512's Avatar
southpole512
Can someone tell me where the battery ground cable is supposed to attach (opposite the battery end)? There was not one on the truck when I got it.
Old Sep 5, 2007 | 10:21 AM
slow64's Avatar
slow64
It attaches via a bolt to your frame. Then there should be a woven copper ground strap from the frame to your engine (bellhousing bolt is a good spot, out of the way and all.)
Make sure the connection points are clean and free of rust, paint etc...
Old Sep 5, 2007 | 12:34 PM
Flyn66dtmn's Avatar
Flyn66dtmn
FWIW- the 65 and 66 trucks with the v-8 engines mounted right underneith the alternator to the engine block. it's quite a large bolt. 3/4 in head, sorry i cant say where the 6 cylindars mounted as all of mine are conversions. there is also a body gound wire in the back of the block by the throttle linkage that attaches to the firewall. Dutch
Old Sep 5, 2007 | 01:13 PM
jowilker's Avatar
jowilker
Right on the money Dutch.
John
Old Sep 5, 2007 | 04:06 PM
Customcab's Avatar
Customcab
The 240 & 300 sixes negative ground cable end are basically connected in the same location as the V-8's. I believe it's a 9/16 bolt head on them..
Mitch
Old Sep 5, 2007 | 05:49 PM
slow64's Avatar
slow64
I guess I have mine hooked up wrong...
Old Sep 5, 2007 | 05:51 PM
slow64's Avatar
slow64
Old Sep 5, 2007 | 10:20 PM
southpole512
Thanks for the help.
Old Sep 6, 2007 | 02:45 AM
garbz2's Avatar
garbz2
Slow
yours is not wrong.. just not stock...
Battery to frame is the best then seperate to the engine and cab is sound.
Garbz
