whats the resistor for?
I just got a new coil for my 352, and the one that was on there says internal resistor. The one they gave me at the parts place is external, which seems to be right. I'm getting ready to upgrade to pertronix and keep the coil i just bought, so i need to know what the resistor is for. Is it to keep the coil from getting a full 12 volts and burning up, or to keep the points from burning up. If it's to keep the coil from burning up wouldn't you have to leave it in place even with the pertronix? I know the pertronix needs a full 12 volts so could i splice at the beginning and the end of the resistor wire and bypass it?
Thanks
Nate
Thanks
Nate
Yes to both. Did you know that the typical stock coil is really rated for only 6 volts? They are a carry-over from the old 6 volt systems. 12 volts will overheat the coil and points weren't meant to carry that much current for very long.
Yes, if the coil needs an external resistor, it still needs one with the conversion.
Yes but you still need the resistor wire for the stock coil. Check out this link, the Galaxie guys got it figured out:
http://www.galaxieclub.com/petronix.html
Barry
Barry
The resistor is to keep your points from burning up. They get too hot if you don't have either a resistor or a resistor wire. You still have to run the resistor if you convert to Petronix. I just did the swap this weekend. Your stock coil has no resistance, the Petronix unit requires at least 1.5 ohms resistance. Thus the reason for the resistor.
