Starting Trouble???
Old Sep 4, 2007 | 07:52 PM
robertlgray's Avatar
robertlgray
Unhappy Starting Trouble???
I have 06 F250 4WD, 40,500 miles. The truck runs great but is slow to start. The Ford house says I have an internal oil leak that is causing the injectors to lose fuel pressure after the engine cools off. Ive had it in the shop seven times for this problem and they cannot fix it
Any help would be appreciated.
Old Sep 4, 2007 | 07:55 PM
Maxium4x4's Avatar
Maxium4x4
If your losing oil pressure the injectors will not fire. Looks like the tech has the problem confirmed, why seven times? and no fix
Old Sep 4, 2007 | 08:00 PM
robertlgray
They have tried different things that I dont understand.
The fuel pump went out at 14K, then two injectors after that.
The rear-end went out at 39K.
All that was part of the seven times, but each time the slow start problem was look at.
Old Sep 4, 2007 | 08:06 PM
Maxium4x4's Avatar
Maxium4x4
Your tech has block off plates to check the pressure, should be no problem. Your injector issues could have been the oil pressure problem. Any chance of seeing a new dealer?
