overdrive
overdrive
i just put 3.73 gears in my truck with a 400 and it revs around 3000 at 110kmph is there a transmission that will bolt up to my engine that has 4 gears the truck is a 78 and an automatic.
I think that an E40D will bolt up, but you will need a computer to run it.
You can use an AOD, but you need an adapter. Try http://lentechautomatics.com/rwdmodels.html
