89 e-150 exhaust
Old Sep 3, 2007 | 04:44 PM
cleeE150's Avatar
cleeE150
89 e-150 exhaust
Hi all new here love forums. I have 89 e150 conv,van 302,aod need to put new exhaust on. all original minus muffler. thinking of cutting daul pipe thats inlet to coverter, I think its 2.5 inch. going daul pipes dual 70s mufflers pipes pass rear passenger wheel. hoping to get more h.p. for trailering, has 2 cats with 400,000 miles on them motor has under 50,000 miles, srry 4 spelling, any sugestions, pics etc thanks much.
Old Sep 3, 2007 | 08:34 PM
2000Ford2000's Avatar
2000Ford2000
You'll gain very little HP doing anything with a 1989 302 exhaust unless you install headers first. I ran Thrush Magnum Glasspacks directly off of stock headers on my first 89 302 because I had them laying around and couldn't afford anything else at the time. I noticed no difference in HP or MPG. I noticed a little difference in sound though.
Old Sep 3, 2007 | 09:03 PM
pfogle's Avatar
pfogle
Keep the cats, and run a straight pipe. It sounds good and it WILL gain a little bit down low. Use a 2.5" single (what we did to our '88) and the thing will pull a loaded 8x14 box trailer all day long.
Old Sep 3, 2007 | 11:11 PM
Club Wagon's Avatar
Club Wagon
You saying original cats, w/400,000 miles on them? Got to wonder just how long cats keep working? Somehow I'd have thought they'd just 'wear' out eventually. IF they no longer serve the catalyst function & there's no inspection worries for eliminating them where you are, you wouldn't be sacrificing anything. There's a chance they could also be partially plugged if the motor ever ran rich or the cats got dented.
Don't expect much in the way of noticeable HP improvement, unless the cats were restrictive. As others have said, there'd be more to be gained by replacing the constricting original iron exhaust manifolds, if you could find headers that will fit Econoline.
I still like to believe cats help combat air pollution. How about a dual system that has a new low restriction, fully functional, cat in each pipe?
Old Sep 4, 2007 | 07:04 AM
cleeE150's Avatar
cleeE150
cleeE150 thanks 4 replies, I read some were cats dont ware out, only damage or plugging, dont know how true this is?. few years ago had muffler replaced with straigt pipe. all from cat back is rusted, full holes needs to be replaced, power band been down 4 while, hoping to get back to org. power , cat could be part pluged, motor runs good, as motor temp go up power gos down not bad but not were it should be, thinking cat could be promblem (motor dose not run hot,overheat) few years ago fuel pressure went out blew lot black smoke ie maybe part plugged cat, dont have inspection here, need to do on cheap, Im part disabled, hope this makes since. wish ive see this site years ago, thanks for help......89 e150 302 aod full conversion, Love my van..........thanks again
Old Sep 4, 2007 | 07:20 AM
cleeE150's Avatar
cleeE150
p.s I also am cocerned about polution, also thinking cats cant be clening exhaust verry well after all these years,miles ect. could go with hi flow cat?. about month ago replaced exhaust manifolds with new stock, didnt know better, till I seen this site, stock headers,down pipe,cross pipe,o2 sens, dual pipe to first cat in great shape, cant find anybody that sells dual inlet cat to fit this setup?. thats why I was thinking to cut dual inlet pipe remove cats and going from there back. thanks
Old Sep 5, 2007 | 04:45 PM
2000Ford2000
I think you can still get Banks headers for it. I know they were still available for my 88 460 last year.
Old Sep 5, 2007 | 05:37 PM
cleeE150's Avatar
cleeE150
thanks ford 2000 (headers interesting) banks does not have 4 my year,model.
