410 engine
Old Dec 12, 2002 | 12:05 AM
Ratsmoker's Avatar
Ratsmoker
410 engine
I have always wondered that myself. Could you imagine a 67 fairlane with a 448 cube FE?
Old Dec 12, 2002 | 07:35 PM
alpo23's Avatar
alpo23
410 engine
> C'mon now, am I the only guy who remembers
>this stuff ? DF
Uh, yes you are the only one to remember this.
The rest of us are too young.......
Eric
Old Dec 12, 2002 | 11:22 PM
bv10 mtors's Avatar
bv10 mtors
410 engine
the knock was lifters without oil 428/410s are also weak in the oiling department without modifications. if you run with low oil preasure very long your rod bearings will be knocking next. sounds like a nice truck
Old Dec 13, 2002 | 01:15 AM
pcmenten's Avatar
pcmenten
410 engine
[updated:LAST EDITED ON 13-Dec-02 AT 02:16 AM (EST)]>Could you imagine a 67 Fairlane with a 448 cube FE?
Funny you should say that. My best friend in high school had a 67 Fairlane GT 390 convertible with a top-loader. That car was [font color="red"]fast[/font]. We spend many a night driving in that beast, including one night when we road-raced a big block Corvette through the back roads of Connecticut. He was slightly faster. A 448 would have cured that.
Old Dec 13, 2002 | 10:56 AM
urban farmer's Avatar
urban farmer
410 engine
>It sounds as if you have a burnt exhaust valve. The oil
>pressure deal could be a few things. Most likely would be
>that your pump bypass is stuck open. I thought the CJ heads
>were modeled from medium risers DF? Ratsmoker,I've read with great intrest a lot of your ideas,knowing the 410 has clearance problems with pistons after rebuild,any Idea if this was a problem with a factory motor,this motor came out of a cop car that he twisted on a bridge rail late one night,maybe to much power for him I dont know?Still this motor only has 40,000 miles on it,and everything was o.k until just lately,gunna pull the heads this weekend,Thanks, Farmer
Old Dec 13, 2002 | 05:10 PM
richlars_7's Avatar
richlars_7
410 engine
>And lets
>stop with this story about mercury threw a 428 crank in
>their 390- WRONG !
OK, your starting to scare me. I just bought a 428 crank and pressure plate to put in my 390 block as suggeted by my machinist. So what will I get?
Rich
62 F-250
Old Dec 13, 2002 | 06:11 PM
jowilker's Avatar
jowilker
410 engine
Rich, I suspect it will turn out to be a 410. IMHO
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Dec 13, 2002 | 10:34 PM
oldroady's Avatar
oldroady
410 engine
geez, i think i remember some of this stuff too. my first car was a 69 mach 1 with a 428cj. talk back then was"what a dog", but it made 440 lbs ft of torque. hard on u joints, clutches and TIRES!
Old Dec 13, 2002 | 11:23 PM
mlf72f250's Avatar
mlf72f250
410 engine
Old Apr 18, 2016 | 08:40 PM
Towman4u's Avatar
Towman4u
Your close.
Originally Posted by dinosaurfan
Whoa, slow down here guys.....where did you get some of these ideas ? I think Jowilker is correct in that a 410 core would be worth 500$, tops. Everything but the crank is ordinary stuff. But as far as being 'not THAT much better than a 390', well, it is. About 100lbs-ft better. And lets stop with this story about mercury threw a 428 crank in their 390- WRONG ! Mercury developed the 3.98 stroke crank. They wanted to get extra torque for the large luxury barges of the day, and the 410 gave 80-100 lbs-ft of torque over a similar 390. Ford was busy developing the 427 Cammer and 482 starlifter engines, and paid them no attention to them at all. The 1U casting # is correct, it would be in 66-68 full size Mercs. It is not identifiable from the outside. Now about the flywheel or flexplate, don't worry about at all. They are available new for the same price as 390 gear.Try Pioneer for flexplates and McLoed for flywheels. If your shop doesn't know how to order the right one, just get the regular 390 unit. Your machinist can balnce it to work fine. ( You are having the rebuild balnced, aren't you ?) After Merc did well with the 410, some Ford dealers started installing the 410 crank in 406 blocks (makes 428 inches) and dropping 427LR heads on the engine- that is how the 428CJ engine was born. Pressure from dealers and HotRod magazine finally prompted Ford to offer the engine as a production item. C'mon now, am I the only guy who remembers this stuff ? DF
The real Mercury 410 did not use 390 top end! I know from experience. Stumbled upon this motor when my dad bought a 69 f100 back in the early 80's. We thought it was a Merc. 390 until the thermostat stuck closed. Went and got one for the 390, (you guessed it) it didn't fit. It was way TOO small. Thats when we found out from a friend (ford mechanic) that it was a 410. He told us at that time it was a 390 that used the same crank, rods, intake and heads as a 428. My opinion is if Mercury created the stroke, then they most likely created the intake and heads as well. Don't believe what's on Wikipedia about the Mercury 410. This motor is insane. It would make a monkey out most of ford's run of the mill motors. I'm not talking about BOSS, COBRA JETS, 427 SOHC. Rated at 330 hp and 465 lbs ft torque. Most likely under rated, it had every bit of that hp and torque. It felt like it had more than that but then again it was in 2wd short bed f100 with 4 on the floor and 411 gears!
Old Apr 19, 2016 | 05:08 AM
jowilker's Avatar
jowilker
Sorry bud, a 410 is a stroked 390 Ford engine. There were 2 size goosenecks used with the T-stats back then. Mercurys ran Ford engines, not Mercury. That engine was transplanted into the truck, not installed by Ford, even if you are a Canook living where the Mercury labeled Ford trucks were sold.
John
Old Apr 19, 2016 | 07:18 AM
hiball3985's Avatar
hiball3985
And he needed to dig up a 14 year old thread to post this misinformation.
SilvrT
Mar 11, 2017 08:06 PM
Pastor Scott
Nov 7, 2016 10:32 AM
Pastor Scott
Nov 4, 2016 03:41 PM
RJL1
Oct 5, 2016 01:09 PM
tristankc
Jun 10, 2016 02:36 AM
