Paint engine with body paint.
Old Sep 3, 2007 | 09:26 AM
sdetweil's Avatar
sdetweil
I am doing this nice 3 stage body paint, base, candy, clear.
I would like to paint the engine (460) the same color. The engine is just coming back from the shop after being rebuilt.. now is the time..
Is this possible, or should I go with one of the ugly POR 15 colors.?
Sam
Old Sep 3, 2007 | 09:30 AM
greythorn3's Avatar
greythorn3
it works
i seen it on trucks tv stacey david did it.. he said that is the professional way to do it.. he also deburred the entire block.. i think it would be super nice.. and im sure it would be as durable.. his was a metal flake i believe. but not sure of the brand.. it was primer basecoat and clearcoat..
Ray
Old Sep 3, 2007 | 04:50 PM
sdetweil's Avatar
sdetweil
Mine is a metalflake too.. so I'd have to do primer, base (flake), candy(depth and darkness), then clear.
Sam
Old Sep 4, 2007 | 12:55 AM
greythorn3's Avatar
greythorn3
hungry
ur making me want a candy apple.. yummmmm
Ray
Old Sep 4, 2007 | 08:13 AM
Frat-man-du's Avatar
Frat-man-du
I have POR-15 on both my 65s show car blocks, heads and intake. I did one in 1998 the other 1990- both are still gloss black. The coupe gets < 50 miles a year the Convt gets 100-150 a year - so no real suprise. I am not sure if regular paint will hold up to daily use, I guess with good prep it should be pretty durable.
Old Sep 4, 2007 | 09:22 AM
SYKOLINCOLN's Avatar
SYKOLINCOLN
regular paint does well, I have done numerous engines, but I sugest using a epoxy primer first before paint and use is as a wet on wet sealer, dotn let it dry all the way, I have done a couple of blocks the only discoloring is around the exahust ports, you can also have the block powdercoated and that holds up alittle better than the regular paint.
