points to electrionc
Old Sep 2, 2007 | 11:55 PM
ncfirefighter46's Avatar
ncfirefighter46
well has any one switched to the eletronic form points ??
using a 351 w dist. in a 302w?? what has to be changed if anything?
Old Sep 3, 2007 | 12:08 AM
Mil1ion's Avatar
Mil1ion
Old Sep 3, 2007 | 12:12 AM
ncfirefighter46
i have the whole wirinig harness and all the stuff from a eletronic setup off a 76 f 100 with a 351 w. some one told me the dist where not the same as a 302w. will they swap??
Old Sep 3, 2007 | 05:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
the first thing i do when i get a points vehicle is put a pertronix unit in the distributer, and then forget about it.
it is way easier then messing with a duraspark conversion. takes all of about 10 minutes.
Old Sep 3, 2007 | 05:40 AM
Supercab's Avatar
Supercab
Wink
The 351W dist. WILL NOT SWAP into a 302.
You might be able to swap the electronic guts over though, but I have never tried this.
Old Sep 3, 2007 | 06:14 AM
5851a's Avatar
5851a
You can swap the parts over, just use the parts from the breaker plate up. You will need to file a slot where the coil wire comes out. It is kind of self explanitory if you have both dist. Hardest part is getting that little wire retaining ring out of the center under the felt pad. Or you could go with the pertronix, my case is always have more time than money.
Old Sep 12, 2007 | 02:54 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
<O
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Sep 14, 2007 | 08:31 AM
ncfirefighter46
thanks for all the info on this, i have got to do something the timings is dead on. but she misses under aload, and stumbles. i never had this problem before, till after i lifted her i think the gear ratio has something to do with it being lift it has changed the gear ratio and she just running at a low rpm and it cant hit the peak rpm for the horse power, and in turn it just put strain on the engine at the low rpm.
