Where does this go/
Old Sep 2, 2007 | 03:04 PM
jasonschwenk's Avatar
jasonschwenk
Where does this go/
While working on my truck today I heard the vacumn pump running and i found a grey vac. hose off but I cannot find where it goes!
The end of the line is circled in red. Can someone tell me where it goes?
My truck is an 03 6.0L F-250
Old Sep 2, 2007 | 03:54 PM
SFeintuch's Avatar
SFeintuch
That vacuum line goes on your heater control valve. You probably knocked it off when you hooked up that oil bypass.
Old Sep 2, 2007 | 04:00 PM
jasonschwenk
Where would that be/
I cannot find any obvisous places for it to land.
Old Sep 2, 2007 | 04:03 PM
SFeintuch's Avatar
SFeintuch
It is inline with your heater hose coming out of the firewall.
Old Sep 2, 2007 | 04:17 PM
6.0superduty's Avatar
6.0superduty
What is the line going into your oil fill tube? What does it do?
Old Sep 2, 2007 | 04:31 PM
npccpartsman's Avatar
npccpartsman
The line into his oil fill cap is for an oil filter bypass setup.
Old Sep 2, 2007 | 04:34 PM
jasonschwenk
Is the connection at the firewall?
Still not finding it.
Old Sep 2, 2007 | 04:38 PM
SFeintuch's Avatar
SFeintuch
It is just toward the center of the truck of your oil filler cap. Under the Intercooler tube
Old Sep 2, 2007 | 05:29 PM
jasonschwenk
I must be brain dead. I am sorry.
Can some one post a pic or something.
I see the heater hose under the intercooler tube but there is no vac line or fittig around there.
Thanks guys
Old Sep 2, 2007 | 06:06 PM
darth_calvin's Avatar
darth_calvin
Jason, try this....
Old Sep 2, 2007 | 07:41 PM
jasonschwenk
Now that would have been easy. I do not have that piece. My hose goes from the heater core to the front of the motor.
Any ideas here???????
Old Sep 2, 2007 | 07:48 PM
SFeintuch's Avatar
SFeintuch
Does your A/C get Cold? Without that valve you should not have cold A/C unless your heater core have been bypassed. Then you will not have heat in the winter.
Old Sep 2, 2007 | 07:51 PM
jasonschwenk
The AC get cold not ice cold but cold. Also the heat works.
What the heck??
Old Sep 2, 2007 | 07:59 PM
SFeintuch's Avatar
SFeintuch
I would think that at sometime the hose or valve went bad and someone just put a straight piece of heater hose in. I think that hose and valve is a one piece dealer part. To fix it right I would think you have to get the right hose and valve from a dealer and put it back the way it should be. Your A/C will get Ice Cold then. Maybe a tech can jump in on the one piece deal, I'm not sure. Good Luck
Old Sep 2, 2007 | 08:40 PM
Maxium4x4's Avatar
Maxium4x4
Want me to tell you where to put it?
You have an 03 which does not have a heater shut-off valve, here is a pic from my 03 to see where the line you have might go. Click Here
