1978 - 1996 Big Bronco
Load distribution package
Old Sep 2, 2007 | 11:07 AM
gekitch111's Avatar
gekitch111
I have a '90 with a manual transmission and a 302. I just bought a 4100 lb trailer. This would be about max. for my Bronco. I am cosidering buying a load distribution package. Does anyone have any experiences with these? Do they work? Any help would be great!!
Old Sep 2, 2007 | 11:24 AM
helirich's Avatar
helirich
If your talking about the hitches that have the two bars that put the load on your front springs. I have some personal experince with them. They work great for levaling your truck while towing. They also make an ajustable slide bar to control sway. I hear it works good too. Sway is not usally a problem on Broncos because of the short distance from axle to hitch. But if your rig is lifted with big tires, it might be. I dont use any of the above when towing, but I only tow about 2400 lbs. I do run higher tire pressure in the rear when towing to help counter sway. My only problem is brakes. Thats probubly because I have big tires and no trailer brakes. I just take it easy.
Old Sep 3, 2007 | 10:24 AM
gekitch111's Avatar
gekitch111
I have electric brakes so braking shouldn't be a problem and I am running 31" tires also. Anyone else have any experiences with these?
