Found a 79 d44
Old Sep 2, 2007 | 03:00 AM
Skandocious's Avatar
Skandocious
Found a 79 d44
I found a '79 Ford high pinion axle with 4.10 gears, complete hub to hub, in perfect running condition for $500. I've been toying with the idea of changing my gears to 4.10s but I flushed the idea since I have no idea how to rebuilt a differential. Seems like axle swaps would be a better option for simplicity sake, and it would be cool if I could swap for a front straight axle and stronger rear while I'm at it.
Is this axle a direct bolt on for my truck? If so, is that a good deal at $500? Thanks guys.
Old Sep 2, 2007 | 03:11 AM
khadma's Avatar
khadma
Carpenter Local 745
I think the range for a d44 is around 200.00 in "as is" condition. (not rebuilt).
What would this go into?
Old Sep 2, 2007 | 03:17 AM
Skandocious
This would be going into the truck thats in my signature of course
I did some research and this is what I found on a kind of "Dana 44 Explained" site:
Originally Posted by http://77cj.littlekeylime.com/Dana44_2.htm
Axles to avoid: 44RS 1978-79 F100, F150 and full size Bronco 44RS. This is a good axle only if left with the factory coil mounting brackets. Be sure to a void the 1/4 inch thick inner tube version. Price is average because high amount of these available.
Best 44RS Axle for swapping: F150 Super Cabs from 1977-79 came with the same axle as the F100 & F150 style (5 on 5.5" wheel bolt circle) except it's set up for leaf springs like the F250. It came with the 1/2" thick tubes and the F250 steering set up. The only real down side is how rare these axles are, and the tall gears they come with. Price can range from average to top dollar depending on how knowledgeable the yard is.
I sent the seller a message and asked if this one is the leaf sprung or coil type. If it is the leaf sprung type then maybe his price is reasonable, since that site claims that type of axle is rare.
Old Sep 2, 2007 | 08:38 AM
lostin90s's Avatar
lostin90s
Yes the leaf sprung 44 are hard to find. I know of 2 and they guy wont sell . I think they were on camper spec ail super cab at least both of these are. Later
Old Sep 2, 2007 | 01:36 PM
96onefifty's Avatar
96onefifty
200 is average for a low pinion not a high pinion as he stated it was. they are quite a bite harder to find. but its not a bolt in swap. it requires a bit of fab.
Old Sep 2, 2007 | 02:49 PM
eco's Avatar
eco
If you are going to buy a used rear end and put it in you rig you should at the very least take the cover off and measure back lash, run out etc. and look it over.
Or better yet, rebuild that rear end and put it in your truck. Buy the Ford service manuals, BadShoe DVD and some tools. In addition to the obvious hand tools, you will need a dial indicator, micrometer, dial type inch pound torque wrench and some kind of spanner for the companion flange...I made mine + a few more odds and ends that the DVD will cover. The tools and manuals will come in handy later on with other projects, you will learn something new and you will get the satisfaction of knowing you did it yourself and knowing that it will last...something you don't get when you install used parts. I spent probably 3 months on mine...off and on a little bit at a time, plus there were times that I waited for a while on parts...but I had another rig to drive. You can buy this rear end and drive with the old one still in the truck so that time is not an issue with working on the new one. If you reuse the axles, carrier, ring and pinion parts wont cost that much at all and the job won't be that tricky because odds are that the shims that you end up needing will be the ones that were already in there (unless someone has messed with it) which will eliminate hours of trial and error...that was not the case with me, and that has alot to do with why it took me so long. Something to think about...
EDIT: Wait a minute...is this for front or rear?
Old Sep 2, 2007 | 03:28 PM
Skandocious
Okay, guess its out of the question. I also realized that in swapping the axles I'd have to buy a new lift kit to replace mine... Not lookin' at spending all this money right now. Thanks guys.
