brake booster????
Old Sep 1, 2007 | 11:24 PM
strokin'_tatsch's Avatar
strokin'_tatsch
brake booster????
ok, when i push in the brake petal it will steadily lose pressure and eventually go to the floor. the brakes are still working, but not well until the petal is pushed in quite a bit. is this problem coming from the brake booster? oh yeah and when i push in the brake petal it makes a wierd noise... maybe sounds like air??? can't quite explain the noise, but i've heard it with brake petals a lot, but never paid any attention to it. thanks guys. oh yeah and where can i find the emergency brake cable that comes through the floor board? mine broke a few weeks ago and i just haven't had time to try to find one. thanks again!!!!
Old Sep 2, 2007 | 05:51 AM
Cuda_jim's Avatar
Cuda_jim
You need a master cylinder IMO.
The weird noise you hear is the rush of vacuum due to excessive pedal movement.
Try rock auto dot com for the e-brake cable.
Old Sep 2, 2007 | 06:01 PM
strokin'_tatsch
put in a new brake booster today and there is no more noise. time will tell if i got the right part or not. thanks jim, i will check that site out right now.
