Wiring
Old Aug 31, 2007 | 02:01 PM
Eric Camirand's Avatar
Eric Camirand
Talking Wiring
I have a 1965 F100 truck and need to find a diagram for the lights, or info on how to get all lighting systems off a two filiment bulb--?? Stop lights, brake lights, directional lights and back-up lights. Thanks if you can help.
Old Aug 31, 2007 | 02:15 PM
ReAX's Avatar
ReAX
Stop and brake lights are the same. The Brake lights and Turn signals run off the same filament. The other filament is for running lights.
Reverse lights are usually broken out of those so they be covered with a clear lens.
Old Aug 31, 2007 | 07:48 PM
Franklin2's Avatar
Franklin2
The turnsignal switch is where the magic happens to let one filament be a turn filament and a brake filament at the same time.
Here's a wiring diagram for a 64. I don't know if it will help or not.
http://www.tocmp.com/tOCMP/wiring/1964F100/index.htm
Old Sep 1, 2007 | 08:14 AM
rbaker6336's Avatar
rbaker6336
[QUOTE=Franklin2]The turnsignal switch is where the magic happens to let one filament be a turn filament and a brake filament at the same time.
http://www.tocmp.com/tOCMP/wiring/1964F100/index.htm[/QUOTE]
64 and 65 should be the same
tjdad62
Aug 19, 2011 05:42 PM
big red ranger
1983 - 2012 Ranger & B-Series
15
Feb 20, 2011 06:29 AM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
redvet
May 28, 2002 09:40 PM
