1992 3/4 ton with a recently rebuilt transmission. 180,000 miles total 20,000 on the new tranny. Been having a problem where the Tach drops to zero, and no matter where you put the selector in any forward gear the tranny selects OD. So you have a choice of OD N R or Park. Can somebody tell me why, and how to fix the Tach problem, when the Tach works so does the Tranny.
Sounds like the tach pickup is going bad. It is the one inch nut with two wires coming out of it on the front of the engine. It is a ford only item about 50 bucks from the dealer. Hope this helps.
A dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Check the wires where they exit the big nut on the oil filler housing , known to short out due to bare wire.....
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
farmert, and PLC you guys were right on, I pulled the sensor cleaned a little bit of grit off and the problem was solved, thanks for your input. I always come to this site before I touch anything, and it paid off again.
