How much for Balljoint replacement?
Old Aug 31, 2007 | 10:51 AM
jvoigt's Avatar
jvoigt
Ok guys, I just had an alignment today at Les Schaub, well the tech showed me that my balljoints are pretty much gone...drivable but to me they need to go. So the tech quoted me about $450 installed for all four balljoints. Does that price sound right? What did you pay for yours if you had them done?
thanks guys.
Old Aug 31, 2007 | 10:57 AM
cgl's Avatar
cgl
Check out
PowerStrokeShop's Ball Joint Kit If you want to do it yourself. The kit is $248.96 and is way easier then tracking the parts down yourself. Less expensive as well in my case. But to answer your question, $450 seems a lot less then some other places charge... Unless they don't replace the seals and o-rings with new ones. I'd inquire about exactly what they'll do first.
Old Aug 31, 2007 | 10:59 AM
jvoigt's Avatar
jvoigt
Yeah I will have to ask what all they replace..thanks.
Old Aug 31, 2007 | 11:28 AM
Badluck's Avatar
Badluck
yea I never ever trust les Schaub they ****ed us one to many times and its stupid, they tried to tell me Mine were toast right after I had them done, then tried to tell me that since my pad were worn out I was going to need new roaters, and calipers as well, which was Bs besaue the rotors were new special ones and the calipers were brand new as well.... IMO they will tell you anything they think they can get away with and with me it was when I was younger and driving my Audi so they must have figured I didnt know **** and would try and get me for as much as possible....... sorry for ranting lol but i hate them !!!!! Anyway Id say either buy the parts and DIY or take it to a smaller shop and see what they say first before trusting LS
Old Aug 31, 2007 | 12:31 PM
stormyrider's Avatar
stormyrider
Just make sure that you specify that they use the MOOG ball joints. They seem to hold up better in these trucks.
Old Aug 31, 2007 | 01:44 PM
GregN's Avatar
GregN
The dealer quoted me close to $1,000. Screw that. $800 if I do my Hubs/Bearings at the same time.
Old Aug 31, 2007 | 02:17 PM
Ed in Maine's Avatar
Ed in Maine
$450 is not too bad, all depends on the quality of joints they put in. If there are china made $25 joints, then that may be a little high. But you figure that it is at least 2hrs labor per side for a pro (3 or more for you and I!), and at $60/hr. That's $250 for labor alone.
Me... I do my own. There are tons of other things you can check out while you are in there: main bearing, needle bearing, yellow o ring, inner hub seal, dust boot seal, etc. If you do it yourself, you can replace all those parts if needed and still be under $450, and use quality parts. Just plan to set aside a good chunk of a Saturday!
Old Aug 31, 2007 | 02:32 PM
jvoigt's Avatar
jvoigt
Thanks guys for the input. I will have to do some shopping around as I to dont really trust Les Schuab but they seem to do well around here.
Old Aug 31, 2007 | 02:55 PM
Ridgerunner500's Avatar
Ridgerunner500
[QUOTE=jvoigt]Ok guys, I just had an alignment today at Les Schaub, well the tech showed me that my balljoints are pretty much gone...drivable but to me they need to go. So the tech quoted me about $450 installed for all four balljoints. Does that price sound right? What did you pay for yours if you had them done?
If your ball joints are pretty much gone they should never have done
a alignment without calling you and telling you about the ball joints it's
just a waste of money because you will need a alignment after ball joint's
are replaced. You're allignment probably won't hold and your tires will get
abnormal wear. Just had my ball joint's on one side done 488.00 with
AC-Delco from the shop I use. The other side were tight.
Old Aug 31, 2007 | 06:01 PM
nmcqueen469's Avatar
nmcqueen469
I paid $515 to have both passenger side ones done about 2 months ago by a small shop.
Old Sep 1, 2007 | 07:09 AM
62trvler's Avatar
62trvler
Is the F350 and F250 about the same process and price?
Old Sep 1, 2007 | 10:08 AM
mech2161's Avatar
mech2161
Labor Time
Ball Joint Replace Front Suspension
Without Dual Wheels
One 3.1
One, Each Side 4.6
All, One Side 3.5
Three 5.2
All 5.9
Old Sep 1, 2007 | 10:28 AM
lookin71's Avatar
lookin71
If I could have got that done at that price I might have scooped up the deal! My truck is 4X4, which always costs more, and I was quoted a "deal" of over $900. Stealership? Don't make me laugh. NO way.
I had just bought new tires and tried to have the alignment done. Good timing. They told me they could not do it because the ball joints were too bad. I know a lot of the people that work there, otherwise they may have done to me like they did to you: charge you for an alignment that accomplished nothing.
Get the front wheels off the ground, place your hands under the tire to the inside of the tire, and lift up and towards you on the bottom of the tire. If the ball joints are bad the tire will obviously move. Mine will move, the left one quite a bit.
So, I need the same rapair done to my truck. This has been written about in this forum. Look here for an awesome write-up: https://www.ford-trucks.com/forums/3...ll-joints.html
I printed this out, color pictures and all. My reference material. My dust seals are just hanging on both sides, so i figure I am going to replace everything!! Including buying some Warn hubs.
My advice is that price is less than half what I was quoted at a Michael Tire store here in Louisville. I don't understand the difference in price. I asked around a little and was told about one thousand would be normal. And they would not do it the way I want it. I may paint a few things while it is all apart.
And yes, get the MOOG.
By the way, on a brand new superduty, they still use these sealed bearings. Wouldn't greasable bearings make more sense?
Donnie
Old Sep 1, 2007 | 10:29 AM
lookin71's Avatar
lookin71
I meant "ball joints", obviously. Not bearings.
Old Sep 3, 2007 | 08:56 PM
GregN's Avatar
GregN
Where is the best place to get MOOG Ball Joints? My Dynatrac Hub conversion just came last week and I would like to replace my Ball Joints while it is taken apart.
Thanks.
