460 ford hard cranking
Old Aug 31, 2007 | 10:24 AM
RICH1214's Avatar
RICH1214
Help i bent two push rods after replacing them now i can not get the mortor to turn like it should in order to start, set the timing as the book said but syill turns real slow, set up wo battereys with jumper but still cranks like the timing is way aff, could i of bent a value also that is not letting the exsost out.
Old Aug 31, 2007 | 01:15 PM
scottie2hottie's Avatar
scottie2hottie
Take this to the 460 forum. They'll help you there. Unless you happen to have an '09 F150 with a 460.....
Old Aug 31, 2007 | 06:26 PM
shelbymustang's Avatar
shelbymustang
how did you bend the push rod in the first place?
did the timming gear chain slip ?
