Possible carb issue?
I have recently upgraded my cam in a fe 390 but now I seem to have a new problem. Low rpm and slow acceleration have suffered dramatically. I understand it will have a loping at idle as it is a couple steps above stock. There is a noticeable sucking noise like a vacuum leak that I can even hear in the cab while driving coming from the carb. Faster acceleration or higher rpms lessens the effect. And noticeable lag time if you just stomp on it. I run a Edlebrock 750 with manual choke.
1979 300i6
01-15-2015 05:46 AM
bradydwest
02-05-2013 10:09 PM
HowardH
10-24-2005 03:18 PM
mkarns
05-31-2005 07:39 AM
