6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
3347 miles towing
Old Sep 1, 2007 | 06:42 PM
Doolittle's Avatar
Doolittle
you know the Ford f350 weighs in at ~ 8000lbs. Its one heavy truck, the Chevy offering is about 2000lbs lighter. Just something to think about.
Old Sep 1, 2007 | 07:27 PM
mattebury's Avatar
mattebury
Originally Posted by top that
4x4 I don't know the weight i keep my speed below 65 I am pulling a 3 horse trailer with 2 horses it is all alum. with a 10ft. living quarters same trailer I pulled with my o3 6.0 and averaged 14mpg with it same load dealer says he is getting same complaint from eveyone that has bought one but he has no answers. Everone in the campgrounds fom N.C. to S.D. semms to have the same problem
Don't quite know what to tell you, but it sounds as if you are pulling at least 12,000 lbs with two horses. I was looking at Lakota 3-horse trailers on the web and they are ~ 14,000 lbs GVW and 8,000 lbs empty, so depending on how much oter stuff you have in the trailer.
With a 3.73, you should be getting better mileage than me with a 4.10 unless you are constantly pulling in the hills. With the 4.10s on mine, I can just go up the grades without slowing down. My transmission doesn't have to shift to a lower gear as often to climb, but I'm just guessing.
For me, with the weight I'm at, I'm happy to be getting 10 MPG towing.
Old Sep 3, 2007 | 04:44 AM
top that's Avatar
top that
Thanks Doolittle that explains a lot same as hauling 40 sacks of feed and the chevy empty no wonder they get better mileage
Old Sep 3, 2007 | 04:55 PM
fruth04's Avatar
fruth04
my dads new 250 with 3.73s empty is getting 14-17 mixed driving and if you really romped on it racing around town... you could get the average to fall to 11.9 but he hasnt towed yet
the reason the chevys get better mileage is because they run 245s on about everything to keep the factory rated "torque to the ground" numbers up , also that is why they do better in stock vs stock pulling tests, 275s vs 245s with the same gears, how can you compare, my f150 would smoke 245s but wouldnt chirp 275s
notice how the halfton chevies have 275s and 265s, they dont give a rip on towing on those because people are less li kely to view that when buying a halfton, but at the same time there is a 1ton right next to it with little sissy tires on it......there is a gravel pit company that my neighbor works for, they buy all chevy diesels, just about all of them go straight to the shop and they put 265s and bigger on them, one or 2 of them are on stock tires and will run circles around the others pulling on the highway...
Old Sep 3, 2007 | 06:51 PM
Als03FX4's Avatar
Als03FX4
I have a F-550 with 4.88 rear. The truck empty weighs in at 11,400lbs. I should mention it has a landscaper dump on it. It has 600 miles on it and I usually tow a 13,000# trailer in 90% city. I am getting 9.2mpg. Might want to get that looked at. I also have an 06 F-350 6.0L and I feel the 6.4L tows better...
Old Sep 3, 2007 | 06:59 PM
DMAX-HD's Avatar
DMAX-HD
I really didn't notice a differance in mpg putting bigger meats (in my case 265's) on my dmax lb7 or dmax lmm. Also don't know what tires would have to do with hp and tq. Those numbers are from the crank. GM did finally offer bigger wheels and tire setup on the 08's
Old Sep 4, 2007 | 02:14 PM
cads03's Avatar
cads03
I've got an '08 f-250, crew cab 4x4 with 3.73's. I've towed a 13,000 lbs boat from cincinnati to knoxville tn. and averaged 8.5 mpg and that was not being nice to it...70-75 the entire way there and back. Empty, I'm averaging 16.5. I had a 2004 with the identical setup and would average somewhere around 17.5-18 empty and around 9 pulling the boat, the only difference was the '04 did not have NEAR the pulling power the '08 has. Needless to say, I'm happy.
Old Sep 4, 2007 | 03:54 PM
firehawk198's Avatar
firehawk198
towed 16650# with my 450 this summer averaged 8.726 hand calculated. My 99 V10 averaged 7.5 by the computer probably about 7.1 actual. Big difference was towing my 450 I could keep it at any speed I wanted on the hills. Liked it better out of cruise control, I could pick it up a little more at the bottom and it wouldn't have to downshift often. On cruise it would drop to about 62mph downshift and get you back up to 67 in a hurry, you could really feel the torque. Couldn't be happier with the way it towed. Oh ya if it got 18 mpg like my Firehawk towing a lot of hot air.
Old Sep 4, 2007 | 11:31 PM
kimminau2's Avatar
kimminau2
I get 8-8.5 towing 20k with my 450. I got about 5.5 towing the same trailer with my 250. And yes my 250 was WAY overloaded hence the reason for the new vehicle. However the V-10 with the 4.56 gears pulled it almost as good. Not a big difference in that respect except the V-10 is rapping out about 5,000rpm whereas the 6.4 purrs along at 2,500 or so. The 10 loves the rpms though.
Old Sep 5, 2007 | 07:29 AM
blue ghost's Avatar
blue ghost
I was not in tow mode I talked to a guy from florida who had over 10000 miles on his truck and he said mileage hadn't changed lucky if he got 8mpg towing very unhappy
Why were you not in tow mode? Thats what it's for. If I forget to put mine in tow mode I will get the downshift shudder. I get 11 to 12 pulling my 35' three axle Avion TT about 10000#s 65 to 70. I really think you would see a big difference in tow mode.
Cajun4396
2009 - 2014 F150
Oct 10, 2014 01:32 PM
jl429
General Diesel Discussion
Sep 19, 2013 05:13 PM
hitchman
2009 - 2014 F150
43
Nov 26, 2009 12:14 PM
wi_bigfoot
2009 - 2014 F150
Jul 7, 2009 04:24 PM
Fomoko1
51
May 21, 2007 02:50 AM
