Oil & Lubrication
Synthetic Replacement for 5w20
Old 08-30-2007, 03:36 AM
fordmtnman's Avatar
fordmtnman
fordmtnman is offline
Hi, I'm running a 4.2V6 in an 07 F150. It came with 5w20, that's what the manual recomends, but I intend to switch to a full synthetic oil. I've never run synthetic oil before, and I was wondering which #'s to look for. 0w30, 5w40, 5w30?
Thanks
Old 08-30-2007, 07:39 AM
Ed's Avatar
Ed
Ed is offline
Mobil 1, Royal Purple, both quality oils, have a 5w20 oil. If not 5w20, I would use 5w30, but nothing else. Especially in a '07 4.2 V6.
Old 08-30-2007, 08:26 AM
whateg01's Avatar
whateg01
whateg01 is offline
AMSOIL also has a 5W20 synthetic.
http://www.amsoil.com/storefront/xlm.aspx
Dave
Old 08-30-2007, 09:51 AM
jim henderson's Avatar
jim henderson
jim henderson is offline
Most big syn makers have a 5W20. I prefer 5W30 syn jus tbecause I think it starts up a little quieter, but could be imagination.
No reason to run anything like xW40 or 50 unless you have an egnine bruning oil in which case syn is probably a waste anyway.
I don't care for 0Wxx since in my experience it does make the engine noisy at startup and there is no real good reason fo it in my opinion unless you live where block heaters are standard equipment.
Just my opinion,
Jim Henderson
Old 08-30-2007, 02:06 PM
R-WEST's Avatar
R-WEST
R-WEST is offline
I'm gonna' give the Pennzoil "Platinum" 5-20 full synthetic (it's got those 'adaptive' molecules, after all ) a try in my '07 5.4, and the wife's Freestyle Duratec V-6 too, starting next oil change.
Old 08-31-2007, 12:27 AM
Melchiah's Avatar
Melchiah
Melchiah is offline
i would go mobil 1 if i were you its more universal in the sense that you can usually find mobil at any parts store
Old 08-31-2007, 03:39 AM
PW01's Avatar
PW01
PW01 is offline
Mobil 1 or Pennzoil Platinum, Royal Purple has a tendency to shear pretty quickly. I'd also stay with the 5w-20, UOA's show this weight to be a consistent performer.
Old 09-01-2007, 07:22 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
In case you have engine problems & seeing as how you have a 07 & likely a Warranty to consider, be sure the lube you use, says on the contaner, that it Meets or Exceeds Fords specifications & stay within the owners manual viscosity range call out, for the temps you'll encounter & for the type of driving you'll do, during the OCI, down in hot country AZ.
Texaco & Chevron make good lubes, that should be available in your part of the country, if you don't want to use Motorcrafts full synthetic.
Just another thought or two for pondering.
BigBlocker0248
02-08-2016 04:02 AM
bushs610
1997 - 2003 F150
04-24-2012 09:12 AM
98woody
04-17-2012 12:06 PM
Skinner F350
02-27-2011 06:09 PM
Aero-fan
Aerostar
21
04-06-2008 01:34 PM
Quick Reply: Synthetic Replacement for 5w20
