Changing Cab Mounts
Old Aug 30, 2007 | 09:03 PM
sctrt's Avatar
sctrt
Changing Cab Mounts
I have a 1985 Ford F150, fuel injected 302 engine.
I am wanting to change the cab mounts on my truck.
I'm having luck with middle and front mounts, but... I need ANY INFO on the Rear mount ~ that anyone can offer !
I am having A Lot of trouble trying to Remove the Rear mounts!!!
Thanks for ANY HELP...
SCTRT
Old Aug 30, 2007 | 10:37 PM
Franklin2's Avatar
Franklin2
What's the trouble, besides the gas tank being in the way?
Old Sep 2, 2007 | 10:10 PM
sctrt's Avatar
sctrt
Cab Mounts
Franklin2
Thanks. I am on the right side of the cab, so the fuel tank is not an issue { will remove it if need be}. Front mount was easy to remove, the center I cut the lower bushing out and used a torch and slide hammer to pull lower part of hardware apart. On the rear there is very little room to do this. I am considering threading a bolt into the bushing nut to use a impact hammer on the top and at the same time using a impact wrench on the nut on the bottom. If this doesn't work maybe I can cut the bottom bushing off and use a torch. TIGHT SPACE ON THIS.
Any suggestions or advice will be welcome.
Also does anyone know where I can purchase new hardware for these bushings?
Thanks
sctrt
