some some kinda problem(i think electrical) help!!!!!!!!!!!
Old Aug 30, 2007 | 08:29 PM
badstuff's Avatar
badstuff
Thumbs down some some kinda problem(i think electrical) help!!!!!!!!!!!
I have a 1989 FORD F150 XLT lariat 4X4 my problem is hard but maybe simple i replaced my starter truck started came out the next day truck wouldnt start without a jump.thought it was the battery replaced it didnt help took the alternator and tested it altenator was good (internal voltage reg) so i started replacing relays and harnesses checked my fuses,and ended up replacing my altenator anyway also my starting solenoid.so my problem is this my truck will start with a jump and run my voltage reading on my gauge inside the truck is low and not showing any kind of good voltage,and when i shut my truck off i cant start it with out a jump.
i really need help for i use my truck for volunteer work for my church and also work i really need it bad thanx to all who give this a shot
Last edited by badstuff; Aug 30, 2007 at 08:29 PM. Reason: wanted to put in year of truck
