Sponsored by: Real Truck
Upfitter Switch?
Old Aug 29, 2007 | 09:28 PM
wanabe2's Avatar
wanabe2
Upfitter Switch?
Did any of the 03 SD 250's come with upfitter switch? I have a oval hole in my dash on the right side of the steering wheel. Did they go in there? Never seen one, and though it would be nice to have.
Old Aug 29, 2007 | 11:45 PM
2003Stroker's Avatar
2003Stroker
I have a 2003 f350 and I added upfitter switches to mine if you put the fuse box behind the glove box and mount the switches where you want them I personally mounted mine to the right of the steering wheel right on the hard plastic that you can't remove it may look like it will not fit but if you place it right there will be no problems. I love them I use them for all my lights when I plow . Just my 0.2 cents hope this helps
Old Aug 29, 2007 | 11:55 PM
riggz's Avatar
riggz
To answer your question, no they did not come on any SD trucks until 2005. You can purchase the parts from ford and cut them in to fit. There's also some kits on ebay that will include all the parts and the instructions.
Old Aug 30, 2007 | 06:35 AM
sofdchief's Avatar
sofdchief
Like Riggz said, 2005 was the 1st model year with the upfitter switches. The small oval cutout you are talking about may have been for the power adjustable pedals option.
Old Aug 30, 2007 | 08:03 AM
riggz's Avatar
riggz
The small oval cutout is just a storage spot. It's kind of useless if you ever stomp on the pedal. I'm thinking about putting upfitters in, if not then one of those dash pads that stuff doesn't slide on.
Old Aug 30, 2007 | 08:53 AM
rwilimo's Avatar
rwilimo
See my post here: https://www.ford-trucks.com/forums/4...info-here.html
scrdanis
Feb 20, 2011 07:09 PM
firemech
Oct 30, 2009 05:36 PM
fordboy2
Oct 23, 2007 06:51 PM
TXBDBY
Electrical Systems/Wiring
Jun 3, 2007 09:33 AM
Jspafford
Mar 9, 2006 10:45 PM
