360 mpg improvement question
Old Sep 5, 2007 | 11:58 PM
customcab66's Avatar
customcab66
The tag on the rear end it reads 3:13 don't know much about this truck it is all original. Have not opened it up to find out for ser yet.
Old Sep 6, 2007 | 12:35 AM
390428cjt's Avatar
390428cjt
what is the axel code on the vin tag on door??
Old Sep 6, 2007 | 12:37 AM
390428cjt's Avatar
390428cjt
What is the axel code on the vin tag
Old Sep 6, 2007 | 12:42 AM
greythorn3's Avatar
greythorn3
maybe its 3:73 misread
Ray
Old Sep 6, 2007 | 11:03 AM
customcab66
The door tag says 17 for the axel. Not sure what that means.
Old Sep 7, 2007 | 06:32 AM
390428cjt's Avatar
390428cjt
axel code
That code (17) is for 69-77 ford trucks it states its a 3.25 ratio
Old Sep 7, 2007 | 04:42 PM
Bear 45/70's Avatar
Bear 45/70
What about the "3.13" tag on the rear? I would believe that over the code on the chassis. I would also suspect a 3.73 rather than a 3.13.
Old Sep 10, 2007 | 09:20 PM
occupant's Avatar
occupant
I don't know why I'm driving my truck wrong but I'm getting 14.3mpg in a '71 F-250 with a 360 and T-18 4-speed. 4.10 gears, too. Maybe I got one o' them high mileage secret carbs or something.
Old Sep 10, 2007 | 09:46 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
With a 68 CS, C-6, 414 I can get your 14.3 mpg mileage with a 670 SA.
Old Sep 10, 2007 | 10:20 PM
RustyTrustyF150's Avatar
RustyTrustyF150
4 bbl intake , dual exhaust , electronic ignition , then maybe some friction reducer in the motor oil and fuel
Old Sep 11, 2007 | 01:01 PM
390fe's Avatar
390fe
Tuning is critical in attempting mileage gains in these old trucks. I've got a cast 4bbl Ford intake, Holley carb, and electronic ignition, and I get better than 15 mpg. My truck also only weighs 4,100 lbs.
Just keep track of your timing, carb settings, mpg, etc, and change one thing a week. Figure out what your truck likes best and keep at it.
Ps. keep your tires properly inflated! :-)
Old Sep 11, 2007 | 01:03 PM
greythorn3's Avatar
greythorn3
seems like allot of MPG have you checked your speedo for accuracy? and what is your routine for figuring your MPG?
Ray
Old Sep 11, 2007 | 01:45 PM
  #28
"Beemer Nut"
Going on 19 years with the same motor different truck with mileage and fuel records. I ran thru mileage marks that have been placed on job the sites plus a stop watch for Mr. Speedo. Tire wear alone can throw things off.
A total of over 922K miles the last 35 years, I record mileage.
The 268 mile one way trips I was taking for years I didn't recall the land shifting closer or farther apart plus a correction added for Mr. Odie as he was 7.3% below the actual mileage.
With literally months of dizzy tuning, running wide band O2 sensors for carb tune, 33" tires with 3.54 gears and not running over 68 mph you can get mileage.
Old Sep 11, 2007 | 09:21 PM
  #29
RustyTrustyF150
Red face
ONE big thing that gets overlooked is tire alignment
Old Sep 12, 2007 | 12:44 AM
  #30
"Beemer Nut"
Nope, 1/64" toe-in on my truck with radial tires.
