Mystery Oil Leak, Please Help!!
Old 09-02-2007 | 09:06 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by greagin
where did everyone get the o-rings? from ford?
Did you find the leak?
Old 09-02-2007 | 09:34 PM
catalinagoose's Avatar
catalinagoose
If there is oil in the valley, check the high pressure pump discharge lines (the braided steel lines that go from the high pressure pump to each cylinder head). The fittings in the high pressure pump frequently blow out the o-rings and leak a significant amount of oil which eventually ends up at the bellhousing area.
Old 09-02-2007 | 11:05 PM
greagin's Avatar
greagin
just ordered o-rings from mcmaster-carr. they are viton brand and i will be installing them as soon as they get here. thanks for all of the help!! i think it is fuel after all!! thanks tenn!!
Old 09-02-2007 | 11:27 PM
Tenn01PSD350
No problem. But it is helpful when you tell us where you found the leak. There are many sources for orings here. Mcmaster will most likely be fine.
Old 09-03-2007 | 07:59 PM
greagin's Avatar
greagin
i have not actually seen it leaking but i think that it is fuel in the valley and not oil. it mxes with engine sludge and lloks like oil by the time it hits the driveway. the front pocket fills up first. i am strongly assuming that it is the fuel drain valve o-rings.
Old 09-03-2007 | 08:23 PM
Tenn01PSD350
Good luck. That fan can really blow things back making it super tough to isolate a leak at times. That is why a clean engine is a happy engine. Some call it ****, I call it having a look every so often before it gets to be a puddle of goo.
As a matter of fact, I attribute the bulk of my minimal oil usage between changes to getting soaked up in a paper towel as I check it so much.
Old 09-04-2007 | 07:22 AM
greagin's Avatar
greagin
as soon as i replace the o-rings i will clean the engine again and check it daily for about a week just to make sure that was it. if not, i will move on to other possible sources but i will let everyone know where it was. hopefully the faulty o-rings are the culprit.
Old 09-04-2007 | 09:11 AM
vettdvr's Avatar
vettdvr
You are going down the exact path I did and it solved my leak.
When you get ready to do the job I did the following:
moved the valve out of the way that blocks your 1 hand work area.
Put a white drop cloth in the valley for my fat hands to drop screws.
Use a torq bit in a 1/4"drive socket to remove the torq screws. (you can't get a screwdriver in the space)
Don't drop the yellow valve lever. (otherwise the white cloth will have to help)
When Installing the o-rings snapped in place and held but the yellow lever won't. I used a tie wrap around it and inserted the top of the lever into the retaining hole and inserted 1 screw. This way you will have something to hold the lever and valve when you remove the tie wrap. After you snug up the screw a bit but not tight you can cut off the tie wrap.
Snug all the screws evenly to compress the o-ring then gently tighten. Don't crack the plastic by over tightening.
I have had a clean engine since doing this work. Relatively easy if you use the tie wrap method (string would work but I had the tie wrap).
Have a nice day. Jim
Old 09-04-2007 | 05:24 PM
greagin's Avatar
greagin
thanks jim, can't wait for the o-rings to get here and hopefully get on my way back to a clean driveway!!!
Old 09-05-2007 | 09:36 AM
WonderDonkey's Avatar
WonderDonkey
Leaks are such a bum deal makes you wanna puch yourself.
Old 09-09-2007 | 04:17 PM
greagin's Avatar
greagin
did the o-rings two days ago, clean engine ever since!!!! thanks to all that contributed!!! Long live the Gurus here on FTE!!!! yall are the best!!
Old 09-09-2007 | 05:42 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
well i did my fuel drain orings yesterday, did Simple Green after it, and so far so good, the valey is dry like like it should be, i had fuel all way back to my fuel tank, it was all over, it looked like oil at first, but every time it got wormer i smeled fuel , so i got o-rings for pump IPR and fuel drain, just did one to see what happens, it was a drain valve,
the one thing i noticed, that if your drain valve swings easly between open and closed position than you more likely have a leaking valve,
very easy to replace,
  #28
Old 09-09-2007 | 05:43 PM
vettdvr's Avatar
vettdvr
Fixed mine also,, how did you get the torq screws and lever on without dropping anything. Jim
  #29
Old 09-09-2007 | 08:32 PM
greagin's Avatar
greagin
just held in place, no problem at all, kinda tight, but my hands are not that big
  #30
Old 09-18-2007 | 10:29 AM
greagin's Avatar
greagin
Okay, i replaced the o-rings and it was dry for a day, maybe even a few days. now it is dripping agin. not at all like it was before though but some. the bottom of the valve appears to be wet (by feel). Should i just order a new valve assembly as i t may be old and cracked on its own or i may have done it putting it back on, or is there another place that it could leak from in that area? any advice would be appreciated.
Quick Reply: Mystery Oil Leak, Please Help!!
