I need help.. I have a 2006 F350 and I have had allot of work done on the truck.
Such as - Banks Intercooler, High Perf Turbo, New head bolts, Edge Chip, High perform Exhaust and High Perfm Injectors. With all of this my EGT's are really high and no one can offer a suggestion on how to reduce them.
I have 3.73 gears and it has been suggested to go with 4.11's to keep it at higher RPM.
any other suggestions to reduce? Also, what is a safe EGT range? I easily get to 1300 and back off to 1200 and that is where I stay at or below.
You need the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and scroll over the list. There is one for your engine that should be very helpful and another for the Super Duty. Either way you can't go wrong.
