Michigan Chapter Join Chapter, Leader: Toyman
Who can help/do the balls joints in my truck?
Old 11-28-2007, 12:18 PM
5.4L to Freedom's Avatar
5.4L to Freedom
5.4L to Freedom is offline
Do them ball joints yet?
Old 11-28-2007, 12:45 PM
mkratz23's Avatar
mkratz23
mkratz23 is offline
Kinda ran out of money. It is definately not going to be a very merry christmas around here.
Old 11-28-2007, 07:42 PM
5.4L to Freedom
I know how that goes all too well, well in comes time for the happy happy ball joints let me know. Been there done that and would love to lay that hurtin on another SD lol
Old 11-29-2007, 08:48 AM
mkratz23's Avatar
mkratz23
mkratz23 is offline
Will it cause my wheels to start to lean in at the top if i let this go? I see that both front wheels are slightly tilted in at the top. I have seen other fords do this.
Old 11-29-2007, 10:12 AM
Capital Customs's Avatar
Capital Customs
Capital Customs is offline
yes it will and will wear your tires if not fixed. you will also need to realign it.
Old 01-09-2008, 06:46 AM
one_wicked_element's Avatar
one_wicked_element
one_wicked_element is offline
The guy who did mine over tightened them.
The steering is almost as bad as before.
Old 01-09-2008, 09:52 AM
Talyn's Avatar
Talyn
Talyn is offline
The ball joints wore out already?
Or your having sloppy stearing?....
explain your symptoms.
Old 01-09-2008, 11:40 AM
Capital Customs
if you did not align it after ball joints were replaced that would be the reason
your steering still was bad. If they were to tight it would be hard to turn left and right and your steering would not return back to center. sloppy steering or loose steering is a sign of loose parts of need for alignment.
Old 01-14-2008, 09:23 PM
bigblockford79's Avatar
bigblockford79
bigblockford79 is offline
Overtightened What?????????
It is impossible to overtighten ball joints, there are a ball in socket joint that is not adjustable/serviceable. You can only replace the assembly. The only thing that gets tightened is the tapered stem into the steering knuckle, which because of the taper will only go a certain distance into the tapered hole in the knuckle. Overtightening the stud will only create the risk of breaking the threads off of the end of the ball joint.
Old 01-15-2008, 10:46 AM
Talyn's Avatar
Talyn
Talyn is offline
They are possible to overtighten, But you really have to reeef on them super hard with a breaker bar.
Old 01-16-2008, 09:39 AM
Capital Customs
Unhappy
using an impact gun to install will also over tighten them. it pull the seat apart and the ball presses hard on the sides. that binds the joint and hard steering happens. then you should replace them again. and align it.
Old 01-28-2008, 11:30 AM
one_wicked_element
I took it to the Ford dealer, and they backed them out a bit. And then I came back a week later and they backed them out again. They didn't want to do it all at once, as they didn't want to break them.
They said they are within spec now.
My steering is still crappy. I bought a used steering box, so now I'm going to buy a brand new one and see if that helps.
  #28
Old 01-28-2008, 05:40 PM
Talyn's Avatar
Talyn
Talyn is offline
did you get an alignment after each adjustment?
  #29
Old 01-29-2008, 10:56 AM
one_wicked_element
Yep. I think I've had about 5 alignments done on the truck so far. I've ordered my Outter tie rods in the mail on their way, and I'll order the steering box tonight.
I plan on getting them installed this weekend and get another alignment done. If this doesn't fix it, I'm going to burn my truck down.
  #30
Old 01-29-2008, 05:58 PM
Talyn's Avatar
Talyn
Talyn is offline
Did you try adjusting yoru stearing box to make sure that was the cause?
autospecial
Events & Happenings
07-24-2007 09:04 PM
e william
Southern Region
08-10-2006 03:01 PM
e william
04-19-2006 10:21 PM
Quick Reply: Who can help/do the balls joints in my truck?
