ND need your help
Old Aug 29, 2007 | 01:28 PM
cobraguy's Avatar
cobraguy
ND need your help
Bill could you give me an application for these clutch parts
C5TZ-7550-D remanufactured disc
C0TT-7563A pressure plate
Thanks Rich
Old Aug 29, 2007 | 04:30 PM
camperspecial65's Avatar
camperspecial65
They have a large application...in a nutshell, they wont work on any 65-6 trucks 2 or 4wd...the only engines Ive found it used on are the 223,262 and 292.
60-2 F100-250 before SER # 180001 3 sp L/D
60-2 F100-250 3spd M/D
60-2 F350 3 spd H/D
60-2 F100-350 4spd hel.
63-4 F100-350 4spd hel.
60-4 F100-350 single rear wheels & pos. action starter, 223 engine. ALL
61-4 F100-600 262 ALL
62 F100-250 from # 180001 3 spd L/D
61 F350-700 4spd hel. and 5 spd M/D
64 F100-350 223,262,292 engines
The pressure plate as I see its been superceded by C0TT-7563-A which Im sure has been superceded several times more.
The application also covers alot of P series and B series trucks.busses but left them out intentionally.
I do have a Q for ND though...on the parts locater Im finding parts Ive found tons of all over the place in the past no longer show the parts around...would you guess the dlrs cleaned house or have unsubscribed to the service?? Is there a way to find out online if a source has unsubscribed from the parts locater svc. ??? Thanks as always :-)
I hope this helps... cs65
Old Aug 29, 2007 | 04:35 PM
cobraguy's Avatar
cobraguy
Thanks CS that what I thought ... for a Y block
Old Aug 29, 2007 | 04:37 PM
camperspecial65
ya...hope its what you are after....
cs65
Old Aug 30, 2007 | 07:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-7550-D clutch disc is also used for 1965/72 F100/350 240 (not 300) 6 cylinder engines, as is the pressure plate C0TT-7563-A
Ford dealers have access to an in house online parts locator service. Not all the dealers take advantage of it. After one year, all the parts are removed from the system and have to be re-entered.
There's another online parts service, that has no connection with FoMoCo. This connects various obsolete parts sellers with each other. It's by subscription only, and as a little birdie just told me, has been down for weeks because of server issues.
Old Aug 30, 2007 | 08:52 AM
cobraguy's Avatar
cobraguy
Thanks Bill I appreciate it.
