IS the tranny going or the TC? or what?
the tranny now has a delay when you put it into Drive doesnt has a delay when you put it into Reverse
whem you puto into D it stays like 4 to 10 seconds doing nothing you have to press the trottle a bit for it to engageand when it does it slips a little then gets ok and drives fine
does the tranny and TC need a flush ? and new filter?
if so where is the Drain plug on the Torque Converter?
1990 5.8 E4OD
OHH yeah almost forgot.. cheked the Fluid 2day as the haynes manual suggested and it was good.. it was perfect
and i read somewhere that the pump makes shure that it engages and i have another problem that they told me that the pump can cause that soo how can i test the pump ? pressure ? or what?
1990 5.8 E4OD
