The rad attached to my 78 460 just has a hose running to the bottom of the truck for coolant overflow. After the last time I replaced the coolant I went by the spec in my Haynes manual which was to fill up to 3 inches below the filler neck. Which is basically the bottom of the rad's top tank. The truck has an issue with running hot in neck-deep traffic and I know part of that is because the rad needs replacing, that's on my to-do list, but I've also come to realize that the people at Haynes don't always know what they're talking about so I'm asking you guys who've had trucks like mine for much longer. Think I should fill it higher? This weekend I might just look at the junkyard for an overflow tank from a later model and install it.
With an overflow tank and the proper cap, such as I set up, you'd never have to pop the cap to refill the radiator. When I pull my cap, the coolant level is immediately below the cap, and the overflow tank has a few inches of coolant in it as well. Just a thought.
Yeah I'll definately install that overflow tank. Had one in my hands a few weeks ago when I was rooting around for something else. Probably cost me $5.
You can make an overflow tank by placing a gallon antifreeze jug, etc., near the radiator and running the overflow tube in the opening. Make sure the tube reaches pretty near the bottom and voila, there you are. Then top off the rad to full, put a quart or two of water/coolant in the jug, a new rad cap that allows syphoning back into the rad, and you are good to go. You can even make it more fancy by drilling two holes in the top of the jug, then run the overflow tube trough one opening and another drain tube through the other and have it long enough to reach near the bottom of the truck so the overflow doesn't get all over the engine. The drain tube should be placed so that it only goes into thte jug a couple of inches or so.
Yeah I know the type. Saw twenty of them in the junkyard yesterday but I was hoping to find something factory for this truck. So far nothing though....I may end up converting to the combo.
I dont think these trucks had them factory. I did see some restored late 60s mustangs that had a vynal bag with "FOMOCO" on them which wouldnt take much room, but I cant find them.
[QUOTE=m78]I dont think these trucks had them factory. [QUOTE]
They're rare if anything. A while back I did see a truck in the yard, I think it was a 79 that had an overflow tank attached to the fenderwell on a metal arm. Looked stock enough to me but I haven't seen one since so who knows..
