Oil pressure increase,??
Old Jan 16, 2003 | 07:39 PM
big block power's Avatar
big block power
I was running my rat bagged 390 2v a bit since it's sitting and
I noticed the oil pressure goes up after a couple minutes, not too
high, but way higher than ive ever seen it go. Usually the needle
sits on the edge of the low side. Theres no busted valve seals floating around, is something stuck? does pcv malfunction cause this?
Dory
Old Jan 17, 2003 | 06:20 AM
jowilker's Avatar
jowilker
Dory, I'm not sure if you are cranking it while sitting and then shutting it down. If so my theary is that it is cold, (oil thicker) so it's going higher. If you are out running the truck and noticing it you may have a blockage in the pump or filter area.
Maybe a place to start.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
Old Jan 17, 2003 | 02:43 PM
tw's Avatar
tw
I wouldnt worry about it too much. You really cant trust the factory guages to really show you much anyway.
Tony Warren
Nebraska
Old Jan 17, 2003 | 02:45 PM
Sunny_in_hollister's Avatar
Sunny_in_hollister
Killgore
May 31, 2014 03:51 PM
quality1construction
Aug 14, 2011 07:59 PM
briansc99exp
Jul 16, 2006 09:14 AM
chellebell101
1983 - 2012 Ranger & B-Series
Jan 5, 2004 02:18 PM
lucki
Oil & Lubrication
Jul 9, 2002 02:44 PM
