Leaf Removal Question
Old Aug 28, 2007 | 08:31 PM
LM14's Avatar
LM14
If you remove some leaves out of the bundle, what are you using for a leaf spring clamp to hold the leaves in alignment when it's put back together? Will just the "U" bolts do it or do you need to add some clamps to keep the bundle together? Talking about removing every other leaf and reinstalling everything.
Thanks,
SPark
Old Aug 28, 2007 | 09:30 PM
Goobzilla's Avatar
Goobzilla
Get new spring clamps. Midfifty has them in their catalog. Slide the tangs thru the top hat and bend them down, like so:
Old Aug 29, 2007 | 06:14 AM
49willard's Avatar
49willard
An alternate is to use the original spring clamps, plug weld the original holes and redrill/trim off the excess length for the somewhat thinner spring pack.
