front axle
Old Aug 28, 2007 | 04:24 PM
tubes1954's Avatar
tubes1954
front axle
i have a 95 f150 with 319.000 miles.can i replace the bushing at the end of the front axle arm. that hooks up to the frame with out removing the spindle and all the other parts. thanks bill
Old Aug 28, 2007 | 04:35 PM
lostin90s's Avatar
lostin90s
Welcome to FTE
yes if you are talking the arm that runs to under cab Raidius arm .Loosen big nut Grind drill out rivets on frame mount . And remove. After you have jacked up of course. Replace bushing and bolt back in with grade 8 bolts. Don't forget to lube the new bushing as squeaks suck . And tighten large nut.
Old Aug 28, 2007 | 05:09 PM
alz's Avatar
alz
I think he is refering to the pivot bushings. Sorry, I've never done them.
