yesterday while I was having my grill shell pulled off of a parts truck and I noticed that the truck ahd 2 vacuum canisters on it. one was a plastic ball style and the other was a coffee can style mounted under the fender in teh wheel well. the plastic one was mounted on top of the fender in the engine compartment. I was wondering why this truck has 2 and would it be best for me to steal both or is the coffee can one enough, being that my truck doesn't have one and I would like to have some assist on the brakes when I am stopping and the engine is idling. how would be the best way to plum one in to the system? is that the factory location for that coffee can style? ( I'm gonna mount it there on mine anyways, just wondering.)
That is the factory location for one of the canisters. There could have been as many as three vacuum canisters. One would have been located on a piece of sheet metal next to the battery for emissions requirements. If you don't want one of them, I will take it. PM me if you are interested.
This information isn't specific to your truck, because I'm not that familiar with that year range. But, my '89 has 2 - one for emissions relays/valves and one for the cruise control. The brake booster's body acts as a vacuum reservoir for the brakes.
To plumb a vacuum canister in, just put a check valve (if not already installed) on the line coming from the manifold and then either "T" off to the canister and the device using the vacuum or run the line directly into the canister and another line coming from the canister to the devices.
I will get both of them. not sure how much they are going to be at the parts place though... bout to go up there and get the 77 grill inserts for that truck... maybe I can trade them to someone for 75 inserts. PM me with how you want to get it.. I will be using the large coffee can style on the truck, don't really know if I want to use the other one cause it goes where I have to sit to work on the truck. If I don't use it then I will have it for you.
...The brake booster's body acts as a vacuum reservoir for the brakes...Dave
yeah, I know that, it's just that when I have to slam on the brakes if someone pulls out or whatever, there isn't enough vacuum left in the power booster for that last 20 or so feet and it gets real hard to stop cause the engine doesn't make much vacuum at idle, so I figgured that if I put somewhere else for it to store, then I should be good.
I don't know if you are restoring a truck and need it to look stock, or just need the additional vacuum, but...
When the vacuum reservoirs rusted out on my truck, I got a couple feet of 4" exhaust tubing and welded a cap on each end. Then attached a 3/16" barb fitting for the vacuum line.
Dave
I have two on my '78, and it looks like a third one was removed. I have a pint size can next to the servo for the cruise control. I also have one underneath the driver's fenderwell, and there is a connection next to the battery for a third one which was removed at one time. I know it was there, because you can see where the retainer for the can was spread to remove it.
Dennis, I guess what I meant to say is that there are three vacuum reservoirs, each of which perform a separate function. One for the cruise control, one for the heat/ac controls, and one for emissions requirements.
My 77 F100 with a 302 C4 only has the little black ball one sitting on the inner fender by the ignition module. But I don't have power brakes or cruise control.
could it be that mine didn't come with one from the factory since it doesn't have any emmisions stuff on it? I find it hard to think that someone would just take one of and not replace it if there wasn't another one.
